Question about Acer eMachines 350-2074 Netbook
Replace eM350 keyboard - Acer eMachines 350-2074 Netbook
Emachine em350 netbook
Please specify the OS. Emachine em350 somes with genuine windows 7 starter and xp home
Nov 15, 2013 | eMachines eM250-1915 Netbook
E-machine em350 beeping when keyboard is atached
The buffer of keyboard is full, keyboard was flooded? Check if any of the keys is not pressed. Also it might be a problem with short circuit or the connection between keyboard, and motherboard is broken
Sep 02, 2013 | Acer eMachines 350-2074 Netbook
HOW TO RESOLVE NONFUNCTIONAL KEYS ON MY NETBOOK?
Hi There,
Do you mean that the keyboard is not working as in, let's say the "enter" key doesn't function, or other keys do not function?
Or do you mean that there are specialized keys (usually media keys) on your netbook that don't seem to function?
If it's the latter, download the media keys application provided by the manufacturer here - http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2262
If the former - purchase a new keyboard. Replacing a keyboard is fairly easy on netbooks and requires little to no skill other than unscrewing four to eight screws. - http://www.ebay.ca/itm/Acer-Emachines-eM350-EM-350-NAV51-NAV50-SERIES-NETBOOK-US-keyboard-/160655260194
Jul 18, 2012 | Computers & Internet
Acer em350
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on. Sometimes the wireless switch might be a button to press. Look above the keyboard or sides for a wireless button to press.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Maybe the wireless card needs to be reseated.
Turn the computer off, remove the power cord, remove the cover from the bottom of the laptop where the wireless card is housed. Sometimes the wireless card might be under the keyboard. Once you find the wireless card, remove the 2 antennas (black and white cables) but remember where they go. Then remove the wifi card from the slot (it might be secured by a screw). Wait 30 seconds then put it all back together and reboot and see if it detects wireless.
You can also try downloading and reinstalling the wireless drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers for the wireless.
May 29, 2012 | Computers & Internet
I AM A NEW USER OF COMPUTER, WHAT IS THE EM350 BATTERY LIFE?
Hello - the Emachines EM350 is rated by the manufacturer as "up to four hours." however such ratings are always a bit inflated. You can expect probably 2.5-3 Hrs. under "average" use.
Hope that helps, Mikeywaf
Mar 04, 2011 | Acer eMachines 350-2074 Netbook
Is there any manual to remove the eMachines 350 keyboard? Any video or something... thanx in advanced.
You can copy the method explained here to replace the keyboard of an eMachines 250:
http://www.insidemylaptop.com/take-apart-emachines-250-netbook/
In your case, the method is the same as explained there.
Feb 07, 2011 | Acer eMachines 350-2074 Netbook
I have a em350 but screen broke so have been using a monitor and it was fine but now it wont work on it so need to be able to restart it without access to start menu etc. maybe safe mode. once prob solved...
You might know this already, but here goes:
The auxiliary monitor settings are set by pressing the Fn key (usually at the bottom left of the keyboard) another (one of the F keys at the top of the keyboard). That F key may have a small icon of monitors with a slash between them. While booting try pressing the Fn key continuously while pressing the F key several times. It will cycle through different settingss of "only LCD" / "Only external monitor"/ both monitors/.... keep doing that it may restore your setting.
Jan 06, 2011 | Computers & Internet
Acer eMachines 350-2074 Netbook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
