Question about Kenmore Dishwashers
Kenmore dishwasher 665.13749k600 update to my problem. Will not start up but has power to it. Door latch switches check out ok. When I press Smart Wash it lights up along with Heated Dry. I then press Start and nothing. Can't cancel out of it either, after about a minute the lights go out.
  • 341 Answers
Try flipping the breaker that controls it and let it sit for a while and see if that resets it. If it does not, the controller board is most likely the problem.
Posted on Oct 23, 2013
4 Suggested Answers
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite dishwasher Options light up but nothing runs.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
I cant get my dishwasher to start
Defective Door Switch?The next thing that could be causing your dishwasher to not start could be the door switch. This door switch is also sometimes called a door lock or door interlock switch. This switch is a safety feature and makes it so the dishwasher will not run if the door is open. If your dishwasher won't start, then it is possible this switch is bad. This switch is located inside the door panel. To determine if the door switch is bad, remove the control panel, locate the door switch, and test it for continuity.
Blown Thermal Fuse?Another part in your dishwasher that could be causing it to not start could be the thermal fuse. This fuse is designed to blow if the dishwasher overheats. If this fuse blows, it will need to be removed and replaced to make your dishwasher work. Most dishwashers have the thermal fuse located in the control panel area. To determine if the thermal fuse is bad, remove the control panel, locate the fuse, and test it for continuity.
Broken Door Latch?The part that holds your dishwasher door shut is called a door latch. 99% of the time this latch is made from plastic. If this latch becomes broken or cracked, it will prevent your door from closing properly. To determine if your door latch is bad, inspect your dishwasher door and be sure the latch is not broken.
Defective Main Control Board?The control board in your dishwasher supplies power to all components. If your dishwasher won't start, this could mean that the board is bad. If you have tested and confirmed working all the other steps above, then the control board in your dishwasher is most likely bad and replacing it would be a smart option at this point.
Jan 15, 2017 | The Video Game Consoles & Games
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
WHEN i START THE DISHWASHER MOTOR IS NOT WORKING
usually when you start the dishwasher, you should hear the inlet water valve operate and let water in. The wash motor cuts in much later. If you do not hear the motor but everything else seems to be ok then the motor has burnt out. But if you hear nothing once you press the start button, then it is likely the cycle is not starting as the door is not locked. This could mean either the door switch is faulty or the latch is not engaging the door switch. It might help to please clarify the situation as above and also provide model number of dishwasher.
Dec 04, 2012 | Kenmore Dishwashers
Cannont get dishwasher to turn on. Kenmore 13843.
it is most likely the door latch switch
Jul 31, 2010 | Kenmore Dishwashers
Dishwasher has power but will not start when start button is pushed
hi there,
if your dishwasher is recieving power and the circuit is controled by a switch,the swtich is faulty,check the swtich by multi tester if switch is defective replace the switch with new one.
check also the door if is tightly closed and latched.The diswasher will not operate until the latcht is prop[erly engagaed.to check this close and latch,closed and latch the door,holding the latch tightly inb place,then still pressing the latch closed, turn the control knob to the ON position.check if the dishwasher work,the latch is faulty and should be cleaned and tightened or replaced.best regard
Aug 09, 2009 | Dishwashers
Maytag dishwasher mdb7601 will not run-
if power to the dishwasher is OK, then the door latch may be the problem. You need to unplug the unit, remove the inside cover to the door and check the door latch switches (may be a pair) with an ohm meter for continuity. Each switch is a make/break connection. If that is OK, the problem could be a power connector to the control circuit board that could be loose.
Apr 23, 2009 | Maytag MDB7100AWB Dishwasher
Does not seem to be getting power
The most common reason for a dishwasher to go dark like this is the door latch. From the wiring diagram, there appears to be two door switches on the unit, which must both be closed for the dishwasher to have any power. They are probably both in the actual door latch. Recommend that you confirm the latch is "latching " properly ... or manually close both switches and see if the DW lights up!
http://www.partselect.com/ModelFrames.aspx?ModelID=272641&ModelNum=MDB6650AWB&mfgModelNum=&ManufactureID=1&Selected=52882&Position=4&mfg=Maytag&Type=Appliance&Mark=6
Good Luck! Please update me with what you find, OK?
Apr 07, 2009 | Maytag MDB6650A Built-in Dishwasher
Dishwasher isn't turning on
Hi
Kindly turn  it off for 10mins and then after restarting press the stop button twice.
Feb 19, 2009 | Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Re-Set the control panel
if you are getting blinking lights on your console you may want to open up the door and visually look inside of the middle portion of your console and you'll observe an opening. this opening is where the latch and strike comes together to enaged power to the power board. you can take a butter knife and press the latch hooks downward. when you press the latch hooks(located on the latch then look at the front side of your console panel (at the same while holding the butter knife inside the latch keeping the latch hooks press down, press a wash cycle (normal, rinse, potspans, etc) and see if there is any more flashing. If not, then there is a bad connection with the latch.
Jun 07, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Open Questions:
Dishwashers Logo
52 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
