Question about Radio Communications
Atlantis 250 will receive but won't talk out, could this be a faulty push to talk button?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Are you sure it isn't transmitting? do you have a PL encoded on the radio you are using as a receiver? disable it so you can hear everything on it. the wrong digital squelch settings between the two radios will make it look like one of them is not transmitting.
Posted on Oct 23, 2013
  • Dale Mcintyre
    Dale Mcintyre Oct 23, 2013
    This radio received from several radio across the mtns on our hunt but no one could receive conversation from this radio
Sends but will not recieve
If the receiver makes noise with volume up and squelch down, then the receiver itself is probably damaged and typically not worth the expense of fixing. If you can't get noise, it may be the speaker. Some models have an external speaker port you could try.
Apr 10, 2014 | Uniden Atlantis 250 Marine Radio
Starter not turning with charged battery atlantis derby 100
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
Scooter won start up any ideas Tilted Forum Project Discussion Community
Scooter won turn over
http://www.49ccscoot.com/manuals/Derbi_Scooter_Manual.pdf
https://www.oemmotorparts.com/oem2.asp?M=derbi
http://www.derbi.com/fr/images/stories/modelos/37/manual.pdf
Dec 01, 2013 | 2006 Derbi Atlantis City 100
Atlantis 250 - have no squelch when unit is on. Battery is charged but can not receive or hear transmissions ie weather reports. Any suggestions?
me too. Also, transmit seems to work fine but the battery level indicator drops a lot after a few short transmissions.
Dec 29, 2010 | Uniden Atlantis 250 Marine Radio
1999 Honda CMX 250 Rebel will not turn over
Hi, Niceguy883 before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Rebel 250 won start Need help advice
Honda Rebel 125 250 450 View topic my rebel won start
Honda TWINSTAR 250 Service Repair Maintenance
https://www.partsfish.com/page/oem-parts-for-honda
Honda CMX250C REBEL 2007 Owner Manual
Sep 16, 2010 | 1999 Honda CMX 250 Rebel
DOES IT HAVE A CALL BUTTON?
It has a PTT (push-to-talk) button. But if you are talking about a button to make a call tone (ringing sound) come out the other radios, the answer is no.
Best regards.
Apr 10, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Constant beep, channel number and tx flashing
Ok this problem is caused by the spring mic jack
Getting rusty
Oct 26, 2008 | Uniden Atlantis 250 Marine Radio
Radio Communications Logo
78 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
