I also have a gas fireplace by DRU (Richeleiu). I accidentally turned the pilot flame off, but don't know how to get it ignited again. I tried the spark igniter and there is a spark, but nothing lights. I also made sure the gas dial is on before lighting...still nothing. I have no manual for it as it came with the house we moved into.
    New Friend:
    Problem Solver:
  • 6 Answers
You need to push the gas supply knob inwards and HOLD it while lighting the ignitor.
Once lit keep holding for 15 seconds and release.
The gas thermo switch needs to warm up first before it will allow a constant flow of gas. Also called the gas fail save device.
Posted on Oct 23, 2013
SOURCE: Stadt Ducted Heater ignition problems
Could be a number of things
Sounds like it the gas valve. If the gas Valve isn't opening or is burnt out then no gas will flow through it.
Also it the pilot is blocked then you wont get and gas coming through to light it up.
I am forever replacing gas valves on the buffalo series units and have found this to be quite a common problem on older units.
Posted on Aug 21, 2008
  • 13 Answers
SOURCE: I have a EVCON furnace DGAT070BDC. I replace the
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Posted on Oct 24, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Vermont Castings
From what you are showing and saying I would say that you have a bad gas valve... Your test B is the most telling in that it pulls the MV's down when you close the wall switch, but the gas valve does not open...this tells me that it is trying but the valve is not opening...
Now... the next problem will be to find that valve... from doing a very quick search, I believe that it is an OEM valve and probably will only be available from the manufacturer or a dealer...
So I would contact your dealer or Vermont castings and try to secure a new gas valve.
If it were a thermocouple problem the pilot would not stay lit...
One other test would be to bypass the wall switch and jumper the gas valve directly to make sure the wall switch is not the problem...
heatman101
Posted on Nov 07, 2010
  • 1015 Answers
SOURCE: We have an older (22
On some gas valves the pilot setting is on the same dial as pilot on and on .on others the pilot light has aseperate button on right side of control dial. If yours has this there will be a cut out on cotrol dial that must be aligned with button to allow it to be depressed to light pilot. If yours has this align control dial cutout with pilot button,depress button and light pilot,hold for about one min. and slowly release,if pilot light stays lit,turn down thermostat and rotate control dial normally to right . There should be arrows or marks on dial and gas valve to line up. If pilot light stays lit turn dial to next position and check to see that pilot is still lit. This should be on position, turn up thermostat and burner should light. If your dial has pilot light setting on it then rotate dial to each position,try to depress dial and when you have right one dial will depress allowing you to light pilot. Follow same procedure as above and you should be in business. Hope this helps.Thank you
Posted on Nov 11, 2010
SOURCE: My Majestic DVR36RN gas-log fireplace
Majestic DVR36RN: Here's what you need to do: Verify gas line is open. (You said you already have done that). Next turn the switch to pilot (you said you did that too). Make sure wall switch is on also. Now press and hold the pilot switch and hit the ignitor. Once it lights you need to continue to hold the pilot switch for roughly 1 minute. Release the knob and the flame should stay lighted. Now, turn the knob to on. You should be all set now.
Posted on Dec 14, 2010
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
My Insta_Flame gas fire place will not turn off completely. We ahve turned off the gas supply now, but before it still had a tiny flame burning even when turned off.
boy that is one sad excuse for a heating guy. how foes this thing flame on? if it doesn't have an electronic spark start mechanism then it operates with a pilot light that will always be going as it uses this small flame (pilot light) to ignite the gas when the thermostat turns it on.
Nov 21, 2014 | Heating & Cooling
Hi, I have an Insta-Flame gas Fireplace where I am house sitting & I accidentally shut pilot light off. I know I have to push in the dial when it's set to pilot & press igniter button but I...
It could be a red push button or it could be black it could be to the left of the pilot knob , if you take the glass off then you can light it with a bbq lighter
Nov 24, 2012 | Heating & Cooling
My gas fireplace's pilot light is on-but when I turn on the electric switch the fireplace will not light all the time. Sometimes it may take 2-3 minutes before it lights up but then goes out after 30...
I had this exact problem.
Open the glass front. Take a piece of fine steel wool and clean the little metal ends where the flames ignite. Sometimes they just get gummed up. It prevents enough flow from getting through to maintain a flame.
Jan 21, 2018 | Napoleon 36" Zero Clearance Top/Rear Vent...
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
DRU fireplace, Model Richelieu Can't figure out how to start, which buttons and knops to turn, gas on, can see the starter sparking, pilot won't egnite. In a house I just purchased
Turn the gas knob to the PILOT position
Press down and hold whilst lighting the pilot
When the flame holds on its own turn the knob to the ON position. Then turn on the wall thermostat or whatever you have to control the fireplace.
Dec 17, 2009 | Washing Machines
Fireplace will not start. I have not had it lite since last winter. I turn to pilot and wait then hit ignite. I get a spark but the pilot light does not light.
your line mite be stopt up get a mach and turn on you gas and see if i lights up if it dont your eather out of gas or your gas holes whare the flame cums out is stopt up
Dec 16, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
