Question about Makita Roofing Coil Nailer AN451
I am trying to fix my Makita AN451, it's double shooting. What parts numbers are the piston stop in the valve head, o-rings I might need and springs.?
5 Suggested Answers
  • 24 Answers
SOURCE: an451 just started double firing
Replace the piston stop in the head valve
Posted on Jul 07, 2009
  • 396 Answers
SOURCE: where can I get a
eReplacementParts.com is the site I prefer.
You can right click and select open or double left click on the link. If that does not get you to the site you can select and copy the site address pasting it into your browser address bar and clicking on refresh or go.
http://www.ereplacementparts.com/makita-an451-roofing-coil-nailer-parts-c-97_575_579.html
I did not see a rebuild kit. However, you can email them and ask about one. Worst case you can individually order the O Ring and other parts.
Posted on Mar 04, 2011
  • 1388 Answers
SOURCE: my makita an451 roof nailer
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Posted on Sep 27, 2011
rufedog
SOURCE: which orings do i need to rebuild the piston on a makita an451 roofing nailer
If you go to your local
makita tools dealer or
makita.com they should list a complete re-build kit for your model nailer
Posted on Nov 29, 2011
Framer not firing
If it leaks at all times then an o-ring/seal is most likely failed. If it only leaks when you try and shoot the gun then it could be a stuck head valve or a jammed nail. Here is a parts diagram so you can see the items and part numbers that make up the trigger should you decide to try and repair it yourself. If available it is usually best to buy a complete o-ring kit and do them all.
Makita AN943 diagram
Aug 02, 2012 | Makita AN943 3 1/2" Framing Nailer
Which orings do i need to rebuild the piston on a makita an451 roofing nailer
Nov 19, 2011 | Makita Roofing Coil Nailer AN451
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
Where can I get a rebuild kit for my makita AN451 new O rings and driver pin
Mar 04, 2011 | Makita Roofing Coil Nailer AN451
Will not build pressure past 40 psi
You have either damaged reed valves or piston ring. Both of which are common problems with this type of compressor. To diagnose: Remove the motor cover, then the four screws holding the cylinder head on. The valve plate is under the head and all eight reeds, five intake and three output, must be in very good condition to work properly. You'll need the valve plate, part number N017592, and head gasket, part number Z-D24819, if there are any damaged reed valves. If they're OK, check the piston ring. Remove the screw holding the piston on the flywheel and pull the con-rod out of the cylinder. The ring around the piston must be in perfect condition to build pressure. The connecting rod kit, part number KK-4964, is the only way to get the piston seal ring.
Jan 17, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Shoots two nails at a time, gun jams
I found the solution to the double shooting happens when the retainer ring on the feeder paw inside half of the coil nail holder. Part #92 (962112-6) retainer ring R-22. I found the clips broken in two of my guns. Now they work great.
Oct 18, 2010 | Makita Roofing Coil Nailer AN451
My Mac5200 compressor was running fine. I took a
piston rings or valves in the head,,, valves are the most likely one.
Dec 13, 2009 | Makita MAC5200 Electric Powered Air...
Nails jam by sending 2 nails at once
You can find a parts list at the following address:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/AN451
Rebuild kit # 192393-0 (search ebay for lowest price) will usually fix your problem. But for immediate/ temp fix try adjusting the depth thumb screw all the way down or all the way up and lower the pressure a little. Sometimes it helps to put the firing pin in a different position. I believe that fine scratches on the oring contact surfaces in the headvalve actually cause this problem. Before you install the rebuild kit, examine headvalve parts with magnifying lens and sand fine scratches with 300 - 400 grit sandpaper. Lube orings in the headvalve with silicone paste (Danco brand sold at Lowes in the plumbing department) it will help get a good seal. For best results replace the headvalve springs. I do not believe that they come in the kit. Good Luck with the repair.
May 10, 2009 | Makita Roofing Coil Nailer AN451
An451 just started double firing
May 03, 2009 | Makita Roofing Coil Nailer AN451
Makita Roofing Coil Nailer AN451 Logo
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
