Toshiba washing machine
My toshiba machine is out of order just washing the cloths but the spiner is not working..... its an automatic machine.... plz guide
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
srsrs_1999
  • 9 Answers
SOURCE: Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Posted on Apr 30, 2009
SOURCE: hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Posted on Jun 30, 2009
canbruce75
  • 1776 Answers
SOURCE: im my washing machine the problem , the water coming in
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no missing or broken blades on the impeller and that the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 03, 2009
  • 1702 Answers
SOURCE: after washing dirty patches are
Hi, Did you put enough soap in, Is there water coming in when machine is turned on?Check all possibilities. Good luck.
Posted on Jun 29, 2011
Haier hwm65tlf
My agitator not working but spiner is fine any answers on how to fix myself please
Jan 14, 2013 | Haier Washing Machines
How to get a spare part of a toshiba semi automatic washing machine
Hi.
It depends on your location. To start you find the local Toshiba support number in your machine's owner manual.
In UK you can also contact: Currys partmaster.co.uk
If you are located in Australia/NZ you can also order from: Toshiba Washing Machine spare parts.
In Malaysia and other Asian countries you can contact: Toshiba Malaysia
Hong Kong: Service & Maintenance.
There are more distributors. Details depend on your location.
Regards.
Ginko
Aug 22, 2011 | Washing Machines
Kenmore Front-Loading Automatic Washing not draining
Change the brushes or start capacitor for the motor depending on which it takes.. The clothes are proberbly wet due to the motor not spinning the water out of them
Aug 25, 2009 | Kenmore Washing Machines
Machine leaks during spin and is not the pump replaced it.
leackege is due to the dead of varshals in the rooter. u r spiner varshals(the rubber type substance between the body and the rooter spiner) must be replaced... if u just used it as it is u r motor wiring burns due to the laekege of water....
my idea helps u ....
Aug 23, 2009 | Washing Machines
I made the stupid mistake of leaving a small pair of nail scissors in my bathrobe before washing it in my WD860 Hotpoint. The scissors must have fallen between the rubber and steel drums as when it...
yes, just remouve the center part of the spiner, is a cap at the top, that is the spiner holder, onscrew it and lift it, then look under at the center.
Aug 12, 2009 | Washing Machines
My clothes have started to smell musty
  1. take the cloth and put it in a bucket and put some washing powder and just immerse it
  2. after 1 hour put in a washing machine click the washing button
  3. drain it
Jul 18, 2009 | Ariston Technologies Ariston AWD12 Front...
My creda iwd12 front load is not working
If the m/c completed the wash cycle, it may be that the clothes have not rinsed, or incorrect prog selected, or incorrect temp selected,
Check to see if the drum actually goes round with clothes in, as a worn or broken belt will obviously stop the clothes from being washed.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Creda IWD12 Front Load Washer / Dryer
Bowl spiner
What is a bowl spinner, my washer is only 3 years old and seems to not aggitate any more. The light come on complaining of either the water is too hot or the bowl is unbalanced. puting my clothes on the cold cycle and balancing the load does not do any good. the wash and spin cycle will run its cource and I get dirty clothes from it!@!#@#$$@@!!!*^!
Nov 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Sep 28, 2007 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
