Question about Lexmark Z2420 Printer
Printer printing text shadow - Lexmark Z2420 Printer
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
I am having trouble with shadowing on my printer quality. How do I correct this?
If the shadowing is not related to the document being printed, You should change the drum! If the shadow is similar to the text being printed, it could be the lamp that has come out of its place. service required!
Good luck
Jan 04, 2010 | Brother HL 1440 Laser Printer
Text has shadows
Run the print head clean wizard in the control panel under printers/faxes section. If that dont work run the alignment wizard. One of these most likely fix it.
May 24, 2009 | HP PhotoSmart P1000 InkJet Printer
Shadow print from 2200d laser printer
This shadow, or backgrounding, is generally caused by excess debris remaining on the drum. This is mostly caused by the wiper blade not dislodging all the waste toner. You will need to replace the cartridge (C4096A).
Mar 22, 2009 | HP LaserJet 2200D Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Aug 16, 2008 | Dell 5110cn Laser Printer
Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
"shadow" print on letterhead and envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER1.gif IF YOUR DARING.)
Jan 02, 2008 | Brother HL-2040 Laser Printer
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
Lexmark Z2420 Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
