Question about Toys
Ferguson Repair Manuals - Toys
Where can i get a massey ferguson 14 wire diagram to re wire the ignition switch
only a few wires there I would say massey ferguson dealer /parts and repair/ sure it could be found on the internet
Apr 17, 2017 | The Toys
How to, valve adjustment MF TO-35 2.2L
Jason, valve lash is to be set hot at .013" for both intake and exhaust. Check the attached links,instruction and guides, 3 rd link is a engine manual. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Massey Ferguson 35 engine
Update on the Ferguson tractor Engine is in
http://manuals.chudov.com/Continental-Engines/Continental-L-Head-F-163-etc-Overhaul-Manual.pdf
http://weldingweb.com/archive/index.php/t-386981.html
Jun 13, 2016 | Cars & Trucks
We need a Repair manual
Hi Susan:
Here's a link that will give you a huge number of contacts where you should be able to find the info that you need.
https://www.google.ca/#q=massey+ferguson+231S+tractor
Cheers and Happy New Year.
Jan 01, 2016 | Toys
Who has manuals for the Massey Ferguson 230?
contact the manufacturer on line for any available pdf downloads.
try e-bay for manuals.
May 04, 2015 | RTO Massey-Ferguson Tractor TE20, TO20,...
How do I fix a clutch on Massey Ferguson 165 1979 tractor. I need a manual to do repair on farm
This is easy. If you live on a farm i assume you have some mechanic abilities. the tractor needs to be split in half. I have done these tractors in as little as 4 hrs. The easy way to seperate the tractor is to sleightly jack up the middle of the tractor,put a jack stand under the front of the transmision. Now move the floor jack forward to the rear of the engine. take roughly half of the weight off of the jack stand. this will allow you to roll the front half of the tractor away from the rear once you remove the trans.bolts,hydro.lines and brake rods.
Sep 15, 2014 | A&I Products A-509057M91,Massey...
Need a service manual Massey-Ferguson 135
This store seems to have tons of Massey manuals and some for the 135 tractor: Massey Ferguson Manuals
Jul 02, 2013 | A&I Products A-509057M91,Massey...
1960 massey ferguson hydraulic filter location
Hello, I would say just go to a NAPA parts store and ask for a filter. If they have one they would show a part number for it. Usually the older tractors for Ford and Ferguson did not use filters or at best had metal filters that you cleaned in solvent and reused. There are Repair Manuals in soft-cover which are available at places like Tractor Supply or online.
The old tractor makers considered the transmission and differential sealed systems. This means like your new car today does not have a filter in the differential. The old tractors had manual transmissions and the filters are common in automatics.
Be careful not to overfill the trans because on old tractors the gear lube will go out the axle tubes and into the brakes. If operated on a slope, it is possible to tilt the axle tube and have the excess lube flow into the low side axle tube, ruining the brakes.
Some of the parts for the Ferguson will interchange with the N Series Ford. Ferguson had some Industry innovations that later were stolen by other makers.
Oct 03, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
Toys Logo
67 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
