Question about Sharp AL 1631 Copier
ERROR CODE WHEN I TURN ON MY COPIER IT SAYS CH
  • 2 more comments
  • Anonymous Jan 23, 2008
    First the toner was blinking so I replaced that....now the CH code is blinking. Unplugged for 30 seconds, still blinking. Checked all doors...still blinking. I'm clueless.
    First the toner needed to be changed so I did that. Now 'CH' keeps blinking. I unplugged it for a minute, but that didn't help. Still turns on with 'CH' blinking. All doors are tightly closed and toner is installed correctly.
  • trishr Mar 18, 2008
    AN ERROR CODE CH IS BLINKING ON OUR COPIER. FIRST IT SAID THAT THE DRUM NEEDED TO BE REPLACED AND AFTER REPLACING THE DRUM, NOW IT HAS CH FLASHING. AND WE HAVE A SHARP AL-1641CS
  • Anonymous Nov 04, 2008
    I have the same problem. But when I re-installed the toner cartridge and firmly closed all doors, the CH went away and everything is fine now.
  • 30 Answers
I believe that that "CH" code means that one of the doors is not fully closed. Not sure because I haven't worked on a Sharp in a couple of years. It's easy enough to check though. Let me know if that helped.
Posted on Sep 28, 2007
  • 62 Answers
What model it could mean dv unit not installed if flashing if solid a door open or copy lamp fuse is blowing.
Posted on Oct 09, 2007
SOURCE:
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Error code ch
CH mean any kinds of door is open or not close properly.Please close door properly.right side or front side.it has a connector switch it is open or displace.
Dec 15, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
Error code.
CH error has to do with your sorter. Check to make sure it is connected properly and see if there is anything jamming inside of it.
Aug 15, 2008 | Sharp AR-207 Copier
Sharp Copier 2025 error steady CH
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
Jul 24, 2008 | Sharp SF 2020 Copier
Sharp AL 1631 Copier Logo
250 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
