Question about GE Refrigerators
My fridge is too warm and I have to adjust the temperature lower every 2-3 days. I had this problem since I brought this fridge. My foods does not last long. I noticed every time I cleaned out the fridge , ice would formed on the coil connecting To the fridge side. This happened when I took the cover off. The black moles love these warm condition. Help!!!! Condition
  • 341 Answers
You might not have enough room behind your refrigerator. There are coils in the back that need air to shed the heat that is extracted from the inside of the box. If this is a new frige, I would call GE and ask them for help. Check this link out:
http://www.geappliances.com/service_and_support/contact/thanks.htm?result=1
Posted on Oct 23, 2013
4 Suggested Answers
  • 1314 Answers
SOURCE: FRIGIDAIRE FRS20ZRGD7 (SIDE BY SIDE) WARM FRIDGE/ COLD FREEZER HELP!
look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost system1.gif too if i can be of help or you need to know something just reply to this post
Posted on Mar 30, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 10 Answers
SOURCE: samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
Posted on May 05, 2011
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Why is freezer way too cold and fridge too warm when the temp display actually states the preferred temp?
Check the fan in the freezer section, its probably not working or turning too slow. Also check the fresh food cold adjustment its really just a door that gets adjusted, but it could be blocked with food, stuck or broken.
Sep 01, 2014 | Refrigerators
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Temperature control
i had food freezing in fridge. dial turned up and cured the problem
Mar 01, 2013 | Maytag Refrigerators
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
    Generic instructions to set temperatures in fridges:
    Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
    To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
    The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
    It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
    Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
    If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
    After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
    Please rate this reply if it was helpful - good luck!
    Aug 11, 2010 | Refrigerators
    Fresh food side too warm
    Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
    http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
    Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
    Frozen food in fridge
    Start with a total clean, vacuum and defrost. Unplug it before cleaning the motor compressor area. Make sure all the coils you can reach are clean. Plug it in and see what happens. If still the same - time to have a tech do pressure tests.
    Mar 29, 2009 | Frigidaire FRT18G4A Top Freezer...
    A funny smell and i think it might be the temperature
    Adjust the knob to 3 or 4 which would be the midway temperature.
    0 would probably be off or close to it. The 7 would be coldest and freeze water.
    If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
    Mar 20, 2009 | Danby DDW1805W Designer Series...
    Refrigerators Logo
    41 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
