SOURCE: Iron not heating up...
I had the same problem. There is a thermal cut-off switch mounted to the top-side of the base-plate. Unfortunately, you have to completely disassemble the iron to get to it. It is an easy replace, just make sure you take good notes on how it's all wired and put together. To disassemble the iron, I did this:
- Mount it in the cord base and move the switch to the "wireless" setting to remove the cord assembly from the iron.
- There are 2 small while nubs on the bottom of the blue plate in back. These are plugs. Pull them out to expose 2 screws.
- Remove these two screws plus the one in the center of the back blue plate.
- Pull the blue plate from the back of the iron and MARK all wires so you know where they go, then remove them.
- You will see 2 screws into the blue plastic base-plate at the back. Remove these.
- Open the door at the front of the iron where you pour the water in.
- Pry the spray nozzle at the bottom out (pry it forward). This will expose a third screw into the blue part of the base-pate. Remove this screw.
- Pull the white plastic and blue reservior away from the blue plastic base-plate. This will expose three screws into the metal bottom plate. Remove these three screws (on in front, 2 in back).
- Pull the blue plate away from the bottom metal plate. This will expose the thermal cut-off. There is a screw with a small metal clip holding it down. This is the part you will need to replace.
I bought my replacement part from a local electronics store. On mine, it was a 240 degree C cut-off. The part I used was from NTE. Part number is NTE8242. It cost me $1.40.
I suspect the reason this blew on my iron is because Oreck engineers didn't expect it to be plugged in all the time (my wife did not like the 'wireless' mode as it did not stay hot long enough so she uses it in 'corded' mode). If you use the iron on it's hottest setting in this mode, it appears that perhaps the plate gets hotter than 204C. That, or Oreck just got a lot of bad thermal cut-off parts and they are cutting off at a temperature lower than 240C.
SOURCE: My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
SOURCE: not heating up, flashing light
It sounds like you have a loose wire, check your plug to make sure the wire connections are sound. The loose connection may be where the wire enters the iron its self. For saftey I would have this repaired by a professional or have it replaced.
SOURCE: Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
