Question about Maytag Washing Machines
When washing makes grinding sound looks like the pully and belt are hitting the plastic cover underneath
    Sergeant:
    Champion:
  • 257 Answers
Grinding sound is obviously the symptom of bad bearing. You need to replace the bearing.
Posted on Oct 23, 2013
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
XboxModifier
  • 123 Answers
SOURCE: Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Posted on Mar 07, 2008
  • 333 Answers
SOURCE: make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Posted on Apr 16, 2008
IFIXALL
  • 868 Answers
SOURCE: FRIGIDAIRE FRONT LOAD WASHER MAKING STRANGE NOISES DURING WASH CYCLE
Depending on where you live use your local directory for assistance.
Posted on Jun 25, 2008
  • 901 Answers
SOURCE: install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Posted on Apr 06, 2010
Grinding noise
Must look underneath machine and verify nut holding up belt pulley has not loosened, if nut is loose, the noise you are hearing is the pulley scraping against plastic cover. if nut loose, unplug unit and remove 2 5/16in screws from plastic cover, remove nut and add loctite to threads, re-install nut tightly, re-install cover and all is fixed.
Apr 03, 2013 | Whirlpool WTW4950XW Washer
Whirlpool cabrio makes grinding noise on the wash cycle
On this style washer the motor has a belt and pully type clutch under the machine called a splutch.There has been an ongoing problem with the nut coming loose and dropping the belt/pully down which in turn hits the safety shield.
Mar 31, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
94 wrangler 4 cylinder makes a whining noise and wont turn over when you try to start it, the serpentine belt does not move, it cranked over a couple of times but it was making a grinding sound and i...
Sounds like something in the engine "froze" or stuck Unhook the battery and try turning the engine with a wrench/rachet both ways. Check the timing belt, if broken the pistons will come up and hit the valves then stop everything from turning. Is one of the pullies stuck? Take off the serpentine belt and check all pullies to see if they turn.
Jan 14, 2010 | 1994 Jeep Wrangler
Machine making loud grinding sound. got belt thighten and it did about 4 loads and the noise has returned
The Water Pump has a shiney metal retainer that can come partially out and grind into the housing causing the pully to slow and stop.
Aug 08, 2009 | Maytag HAV3460AWW Top Load Washer
Washer makes grinding noise
many of the Maytags have had a problem with the pump bearing. This is what it sounds like. Tilt the washer back. Look underneath and take the belt off. The pulley on the pump is metal. try turning with your hand both ways. If it grinds that is problem. Let me know if need more info.
May 22, 2009 | Maytag Washing Machines
Whirlpool washer not draining
most top loaders use belt drives, it sounds as one of the belts has snaped. can you see a belt laying around a pully or on the floor of the washer that has come away , or a pully with out anything to turn it.
May 14, 2009 | Admiral AW22 Top Load Washer
My washing machine won't agitate and it's making a grinding noise
if its direct drive ( no belts ) there is a plastic coupler that joins the motor to the transmission that shears off when the machine has been overloaded. lay machine on its side look from underneath and look for small plastic pieces on the floor and if so you need to replace the coupler this has happen to us alot of times and we have fixed it ourselves . hope this helps
Jan 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Hi ive got a daewoo espero the cam belt has come off ive got a new one to put on but need the too time marking s to put the cam belt in right please can you help the model i have a put down isnt my car its...
Required tools: 13mm open end wrench 10mm shallow and deep socket 8mm socket long flathead screwdriver 17mm deep socket T50 torx socket 1/4", 3/8ths and 1/2" ratchets and extensions E10 inverted torx sockets 6mm allen wrench 15mm open end wrench 7mm socket 12mm open end wrench 14mm socket 12mm socket 8mm, 9mm and 10mm allen head sockets 19mm socket prybar needle nose pliers If you are doing this because your timing belt broke you will also need to buy a complete cylinder head, head gasket set, and both idler pullys. ALL DAEWOO MODELS WILL BREAK THE INTAKE AND EXHAUST VALVES WHEN THE TIMING BELT BREAKS. Start by removing the air cleaner assembly from the throttle body, remove the air filter and housing jack up the vehicle and remove the wheel, remove the plastic shielding in front of the accessory drive belt assembly, remove the accessory drive belt, place a jack with a block of wood on top underneath the engine oil pan remove the front engine mount, remove the crank shaft pully ( the 4 allen head bolts only not the 17mm bolt in the center.) remove the metal plate behind the engine mount bracket on the engine, remove the plastic timing belt cover 3 clips on top 2 10mm bolts on bottom. Rotate the engine until the #1 cyl. is at Top Dead Center on the compression stroke or line up the crankshaft timing mark with the mark on the inner timing belt cover ( notch in cover with notch in pully) on the camshaft pullys -- ( intake cam line up the line on the pully with the line on the inner cover)( exhaust cam line up the arrow on the pully with the arrow on the inner cover) loosen the 13mm bolt in the belt tensioner and using the allen wrench rotate the tab until there is slack in the belt. Remove the belt. At this time I would reccomend you replace the water pump, both plastic idler pullys as they tend to overheat and lockup, and the belt tensioner. Make sure all your marks are lined up, you may need a helper to hold the Exhause Cam in place as it tends to move during belt installation. Put the timing belt underneath the crankshaft pully, install the belt leaving the intake cam for last and NO BELT SLACK on the right side between the crank and the exhaust cam. Once the belt is installed rotate the crankshaft over 2 revolutions and make sure is rotates freely, and your timing marks are aligned perfectly if not the engine will not run properly, tension the belt as needed. Installation is the same as removal. To clarify, on the DOHC engine, the intake cam gear has a line on it, and the exhaust cam gear has an arrow on it. These should be lined up with the corresponsing line and arrow on the VALVE COVER, pointing straight up. I just went through this process over the weekend, and spent quite a bit of time looking for these marking as I had removed the valve cover. Once I found them, it was plain and simple. In addition, be sure to not over tighten the belt when reinstalling. The tensioner has markings on it for "old" and "new". DO NOT adjust past "new", as the car will sound like a jet engine, and the belt will not last for very long. One more item that you may as well replace while you are in there is the cam position sensor if you have not already, as there have been issues with them, and the timing housing has to be opened to get to it
Nov 25, 2008 | Daewoo Leganza Cars & Trucks
Washing machine was transported, ever since the motor makes a very loud noise
If it sounds like a grinding noise you may have bent something that is rubbing the pulley.  check under the machine and look for anything comming in contact with the pully of the belt tensioner if it has one
Good luck
May 30, 2008 | Samsung Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
