Question about Samsung WF328AA Front Load Washer
Samsung dc68-02807a-01 door can't open - Samsung WF328AA Front Load Washer
Lg tromm washer
The DE or DOE (Door open error) error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 22, 2014 | LG 4681EA2001D Original Water Pump Drain...
DC68-02830A-01
I have never dealt with that brand, but sometimes doors require you to push in before opening. Seems silly and you may have already tried it, but worth a shot. Other than that, try reseting the machine - it may unlock the door. You can also try http://www.applianceservicecentre.ca.
Jan 09, 2014 | Samsung WF337AA Front Load Washer
Fisher and Paykel Nautilus Dishwasher 01 error approx. 15 mins after starting
01 is a door switch fault. it is possible that the switch is corroded and the moisture is causing it to fail, making the machine think the door is open, and it will stop and tell you this.
if you can open the door, and inspect the switch, see if it clicks when pushed.
Oct 25, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Forgot my samsung gt-c3312 phone lock code
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 21, 2012 | Samsung GT-C3312 Cellphone - Unlocked...
My 1998 park avenue passenger doors wont open
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working ?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close? http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
-----------Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working? http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
-----------Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote? http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html -------`-
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
--------Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
--------This will help.Thanks.
Feb 22, 2012 | 1998 Buick Park Avenue
Cant get the pop up lid open where u put the memory card
Is this a 40 GB model?If it is then the "door" is fake and wont open. If it is a 60GB or higher then it shouldn't take anything to open because there is no latch or anything on them. Check your model number on the back of the unit if it is a CECHG-01 or CECHH-01 then it is a 40GB model and doesn't have the SD or CF port and the door is fake.
Aug 11, 2009 | Sony PlayStation® 3 (60 GB) Console
How can i program my garage door to open from my 01 jeep grand ch
Hold down the button on your garage door opener while pushing one of the 3 buttons on the overhead console in the Jeep. It will beep when confirmed.
Jan 05, 2009 | 2001 Jeep Grand Cherokee
Door alarm goes off every 4 minutes (plays music}
i'm got a Samsung RSH1DTMH side by side and its doing the same thing. it seems to be once a week. Last night i opened it to get a drink about 23:30, and then dealt with the alarm, reset 10-15 minutes until 01:30 and then said "F-it" at that point i didnt care if i lost everything i n it. it stayed at -25 in freezer all night, +7 (set to +3) in fridge all lights on, normal operation noises. WHAT THE F GIVES SAMSUNGGGGGGG
Oct 12, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Samsung WF328AA Front Load Washer Logo
240 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
