Question about Dryers
Secheuse moffat rckh315efww
My dryer do not get warm anymore. It just blow air ?? And I already checked all filters, it's all good and clean.
  • 5 Answers
SOURCE: not blowing hot air anymore
there are two thermostats..one above and one below the heating element..they probably need to be replaced..about 30 bucks canadian..have the shop check your heating element for resistance I had the same problem with my Whirlpool, when I called around for prices one shop suggested the thermostats and then tested my element for conductivity. When it passed he sold me the thermostat replacements(they are sold in pairs) They were very easy to install, just make sure the wires are on correct..Check for small marks beside the leads and then match them up while removing old and installing new. I hope this helps
Posted on Apr 11, 2007
ltfrc
  • 227 Answers
SOURCE: Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Posted on Jan 13, 2009
  • 175 Answers
SOURCE: Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Posted on Jun 09, 2009
  • 314 Answers
SOURCE: 99 VW Beetle blows warm air when you start air conditioner
your condensor fins could be blocked by leaves or other debris on the outside. this component is located right behind the radiator. there could also be an overcharge or under charge in the system. make sure that when you charged the system that you used a good set of gauges to check the system pressures. Also check and make sure that there is not a blockage somewhere in the lines, Usually if there is there is a fine layer of ice surrounding it.
Posted on Jun 25, 2009
redgs95
  • 15 Answers
SOURCE: unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Posted on Jul 28, 2009
Kenmore 592-89079 01 no heat wont dry clothes
that model number doesn't come up on parts site,open the door,look around the opening where you put the clothes into dryer and you'll see a tag with the model number,usually if the dryer hasn't been cleaned out and the vent line also hasn't been done the high limit or thermal fuse will pop as a safety because the dryer is running to hot from the air not blowing out.all a dryer does is move air,if there's a block in the vent line,outside at the hood where the air blows out like if there's a cage or screen that lint can get trapped in or in where you pull the lint filter out then the one of the t-stats will pop and are non resetable.also make sure you have 240 volts going to the dryer,you can check that behind the dryer where the plug connects to the dryer with a meter,if there is 240 volts unplug the dryer,remove the bottom panel,pull out the lint screen then remove the screws that hold the metal duct that the filter slides down into,on the right top of the blower wheel ousing you'll see the thermal fuse you have to remove at least one of the wires to check it with a meter,set the meter to ohms say 20k,touch the leads together and you should see anything but 1 on the meter,when you stop touching the leads you should see the 1,now put one lead on one side and the other lead on the other post on the thermal fuse,if you read 1 the part is bad or open,if you get anything else but the 1 the part is good or closed.if that's good,move to the right to the heater,pull one of the red wires off of the heater and read it the same way,if that reads good most likely you'll have an open high limit t-stat on the left back of the heater can.these are the things to check,also if you don't clean out the dryer and vent line the new part will pop again,i use a leaf blower to blow out the vent line,it works great,just remove the vent line from the back of dryer,stick the leaf blower in it and blow all the lint to the outside,with a shop vac you can vac up all the lint inside the dryer cabinet,then set the vac to blow and blow all the lint off the motor and from the back of dryer to the front and vac it up,heep doing this until clean and clean out the metal duct that the filter slides into,do this every year and your clothes will dry on time,you'll save energy and money,your parts will last longer and most of all no dryer fires.good luck,if you need anymore help let me know.
Jun 30, 2014 | Kenmore Elite HE4 Electric Dryer
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
My Maytag gas dryer model LDG9801AAL has irregular heating. The flame is not 100% bluish even after I cleaned the igniter glowbar. I already changed the dryer sensor but the flame keeps getting shut off...
if the flame is liting the ignotor is good,if the flame goea out after a minute or so then you have to clean out the dryer,unplug it,clean out the duct that the lint filter slides into,clean out the cabinet where the motor is and if the vent line is a long run i use a leaf blower to blow it out,pull it off the back of the dryer,stick the leaf blower into the vent and blow all the lint outside.one more thing if the flame lites and after 10 to 30 minutes thee flame doesn't lite anymore you have bad gas coils you can remove the cover down on the bottom right side of the front panel to check this,also you should clean this dryer at least once a year so you don't have a fire and your clothes will dry on time,pull the vent line off the back and see if it runs any better but you still have to clean the lint filter duct too,the block could be in there,bad air movement will cause this to happen.let me know how you make out.
Sep 25, 2011 | Maytag Dryers
Clothes come out mostly dry, but need to run a 10 or 15 more minutes to completely dry. Towels need 2 drying cycles. Lint filter is clean. Lots of lint behind dryer and I notice a lot of lint on...
you need to clean out the dryer.somewhere lint is blocking the air movement.pull off the vent line,if it's long blow it out with a leaf blower,then clean out the duct that the lint filter slides into and vac out the cabinet where the motor is.if it's gas you should do this once a year electric once every two years.
Feb 17, 2011 | Dryers
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
Kenmore gas dryer no heat . 90 series model 110.70902990 have power, did vacum lint from access panel@ FRONT
unplug the dryer,remove the lint filter,take off the bottom panel and remove the duct that the lint filter slides into,clean the duct out,while you have the duct off on top and to the right of the blower wheel housing you'll see a 3390719 thermal fuse,remove one of the wires and check it with your meter to see if it's good,most of the time if the dryer hasn't been cleaned out the fuse will blow,the dryer runs to hot and the fuse is a safety so you don't have a fire and so the dryer doesn't run hotter than it should. vac out the inside of dryer and if you have a shop vac it blows on the other side,blow off the motor and blow the lint from the back forwards so you don't have to remove the drum,next you have to clean out the vent line,if it's a long run from the back of dryer to the outside flapper i use a leaf blower to blow out the line,you should clean the dryer once a year,if the fuse is good you need to check with your meter the ignitor,the sensor and the gas coils to see what's bad,if you need anymore help let me know,good luck,when you're reading anything out with the meter make sure you remove at least one of the wires or you'll get a false reading
Mar 16, 2010 | Kenmore Dryers
Dryer working but only blows warm so takes ages to dry washing
if its blowing hot air only and not turning the drum, sounds like the belt...
Oct 08, 2009 | Dryers
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
DRYER WILL NOT ADVANCE ON CYCLES - ONLY ADVANCES ON TIMED OR AIR DRY CYCLE - CHANGED TIMER AND STILL SAME PROBLEM - MOFFAT EXTRA LARGE RESIDENTIAL DRYER - MODEL RDXR473ET3WW THANKS ANDY
Your sensors are bad or at least need cleaning. Also check the sensor wires. They may have come loose.
Clean the sensors with alcohol.
Apr 14, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
