Question about Samsung RGSF5330DT Gas Kitchen Range
Oven won heat unless burner is on
When turning on my oven, I have to start up a burner before the oven will heat up. It is almost like the burner will ignite the oven, to heat. If i do not do this, the oven itself does not heat.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Check the oven ignitor, it may be bad. See if you have power going to the ignitor.
Posted on Dec 29, 2013
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
Neither the oven nor the broiler burners will light. In both cases, the igniter glows, but no gas to the burner.
UNLESS DOUBLE OVEN THE BROILER BURNER HEATS THE OVEN. AND THERE WOULD ONLY BE ONE IGNITER. WHICH IS PROBABLY DEFECTIVE AS THAT IS A COMMON PROBLEM WHEN USING IGNITER.
Mar 10, 2010 | Maytag MGR5750 Gas Kitchen Range
I have an old double oven white -westinghouse stove and while i was at work the fuse blew in the basment. well i have reset it but now everything works but my stove. well my oven light will not come on...
Hi, sounds like your oven is a 240 volt electric.  One of your fuses is still blown. 240 volts requires 2 hot legs and obviously you have only one. When you turn on a burner, it completes the circuit to your light. Bottom line, you only have 120 volts to your oven, check the breakers or fuses. Good luck!
Jan 29, 2010 | Kitchen Ranges
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Samsung RGSF5330DT Gas Kitchen Range Logo
157 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
