Question about Samsung Washing Machines
Barrel does not spin right - Samsung Washing Machines
    Master:
  • 818 Answers
Greetings Shawn, you could have a belt off or on a newer machine an actuator that has failed-popthe machine open and take a look-cheers Denny
Posted on Oct 23, 2013
Whirlpool duet washer won't spin. I cleaned the clogged pump, but it shows thes two codes
I've had the same issue, and a close friend that had a similar issue. Here are the 2 resolutions:
1) Check the drum in between the body and the actual barrel. Sometimes small articles of clothing get stuck in there and will cause the barrel to not spin (such as a child's sock).
2) Some barrels are only made to spin when the machine is cycling. If for any reason you or someone else spun the barrel with your hand (when pulling laundry out for example), the spinning mechanism can become unattached. In that case, you will probably want to call a repair person rather than taking the washer apart yourself. This is a relatively easy fix for a good repair person so it shouldn't be very costly.
Hope this helps.
Nov 28, 2012 | Washing Machines
I have a bmw 316i compact and my key will not turn the ignition no more any answers
Hi
Very common fault, is the key just spinning around? if so the ignition barrel is hot so you will need a new one, if you dont have time right now to fix it then turn tha car off turn the steering all the way right then put the key in the ignition while also turning full steering lock right, this often gives the barrel switch some grip and you can start the car.
Do you need more specific information on how to repair this yourself?
If so do get back to me and I will tell you how.
Regards
Dan
Dec 30, 2010 | BMW 318 Cars & Trucks
The barrel won't spin. the heat is still working, but the barrel won't spin. i may have overloaded the dryer (five pairs of jeans and three hooded sweatshirts) there was a loud bang noise and the barrel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 29, 2010 | Dryers
Key in ignition spins then engages
You have either a worn key or a work ignition barrel.You need to try a new key first and if the fault persists, replace the ignition key barrel
Jun 05, 2010 | 1997 BMW M3
Neff washing machine - barrel doesnt spin
I would recommend it. Otherwise they will have to run new wires from control module all the way down to the motor. I would get my money back since they didn't replace the right piece.
Jun 23, 2009 | Neff W4380X1 Front Load Washer
Barrell doesnt spin
Check the drain hose if to low to ground if so raise hose up to even with the tub top or two thirds up on machine. Some washers don't spin until water is drain out first then the pressure switch turns the timer to spin. Hope this may help.
Jun 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 70 series barrel will not spin in spin cycle
A clutch is easy to replace on these models. check out this fab directions entitle:
CLUTCH REPLACEMENT
Apr 10, 2009 | Washing Machines
Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Mod 110 keep spinning
the holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Washing Machines Logo
19 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
