Question about Quartet gbc Gbc 1701720: Pinnacle 27 EZLoad ? Roll Laminator
GBC pinnacle 27 not getting hot enough - Quartet gbc Gbc 1701720: Pinnacle 27 EZLoad ? Roll Laminator
I have a GBC Ultima 65 Laminator and the lamination is not adhering. The materials I am laminating are coming apart.
Are you letting the laminator reach operating temperature? If the ready light is on and it is not getting hot then you may have a problem with the temp. sensor. Put your hand near, but not on, the top roller to feel if it is getting hot. Don't touch the roller in case it is hot. If it is getting hot then wait for the ready light to illuminate(about 10 minutes).
Feb 14, 2017 | Gbc Office Equipment & Supplies
GBC Pinnacle 27. Right side top heat shoe does not get as hot as left side. Lamination is milky colored on right side
Could be one of the elimebts have burnt out as there are more than one into the tip just take to local shoe repiar as taking it to golf shop will be expensive
Sep 03, 2016 | Cars & Trucks
Our machine is starting to squeal when working what do we do
There isn't anything you can do, those machines are screamers. sometimes they start screaching right away, sometimes it takes a few rolls of film run through before they start, but they ALWAYS start to scream, sooner or later. it becomes loud enough that some people refuse to use it because they think its coming apart. not my favorite.
Sep 18, 2014 | Gbc Pinnacle 27 Ezload Roll Laminator, 27...
Pinnacle er-1
left hand side cover is probably off and excess light is getting onto the motor speed sensor. put the side cover back on and try it, most likely that will fix it. could also be the set screw on the right side is loose, error 1 means you have a speed problem. check gears and chain. only other part that has caused this in the past is the keypanel.
Sep 15, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Gbc pinnacle 27 ezload power light turns on but the front panel does not
you have one of the TCO's that is blown out, To test them you need to take the right side cover off, and test continuity from one side of the tco to the other, start with the tco wire that is connected to the tray switch, the other end of the tco wire is connected to the wire block on the right side of the laminator. just follow the wires back to the heat shoe and check for continuity. A TCO is no more than a temperature fuse. you can actually make a test "jumper wire" and jump across both connectors and it should power right on. You need to be careful and follow the wires back correctly so you don't fry the laminator the rest of the way.
Mar 31, 2014 | Office Equipment & Supplies
Gbc h415 lock off
Olease use Google Translate to ask questions in English
If your laminator is on maximum and it is still not hot enough, get in ouch with the maker.
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
I have a gbc heatseal h425 laminator and it wont turn on. Is there a fuse inside the machine that needs to be replaced
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Dec 23, 2010 | Gbc HeatSeal H425 Laminator
Quartet gbc Gbc 1701720: Pinnacle 27 EZLoad ? Roll Laminator Logo
43 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
