Question about Samsung RGSF5330DT Gas Kitchen Range
Oven won't heat unless i turn on a burner - Samsung RGSF5330DT Gas Kitchen Range
Elite dual fuel range/oven. Why isn't it heating past 100 deg and burner igniters do not spark?
sadly it sounds like you need to call a service repairman . being an appliance that can explode I do not suggest you try and fix it yourself .
Oct 27, 2015 | Kenmore 30" Slide-In Dual Fuel Range...
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Oven won heat unless burner is on
Check the oven ignitor, it may be bad. See if you have power going to the ignitor.
Oct 23, 2013 | Samsung RGSF5330DT Gas Kitchen Range
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
Neither the oven nor the broiler burners will light. In both cases, the igniter glows, but no gas to the burner.
UNLESS DOUBLE OVEN THE BROILER BURNER HEATS THE OVEN. AND THERE WOULD ONLY BE ONE IGNITER. WHICH IS PROBABLY DEFECTIVE AS THAT IS A COMMON PROBLEM WHEN USING IGNITER.
Mar 10, 2010 | Maytag MGR5750 Gas Kitchen Range
I have an old double oven white -westinghouse stove and while i was at work the fuse blew in the basment. well i have reset it but now everything works but my stove. well my oven light will not come on...
Hi, sounds like your oven is a 240 volt electric.  One of your fuses is still blown. 240 volts requires 2 hot legs and obviously you have only one. When you turn on a burner, it completes the circuit to your light. Bottom line, you only have 120 volts to your oven, check the breakers or fuses. Good luck!
Jan 29, 2010 | Kitchen Ranges
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Samsung RGSF5330DT Gas Kitchen Range Logo
21 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
