Question about Stihl Br420c Magnum
My br420c blower runs fine for about 20 seconds and then shuts off like the switch has been turned off
  • 2,113 Answers
Possibility 1) It sounds like it is sucking air with the gasoline. 2) don't rush the choke, leave it running on high with 1/2 choke. When you go to move the choke to off, move it very very slowly while the governor can catch up and raise the revs. Or slow the revs down before turning the choke off.
Posted on Oct 23, 2013
  • mikadot
    mikadot Oct 23, 2013
    Also don't use gasoline that has ethanol in any 2 stroke motors. Learn who has real gasoline and what octanes they are. Ethanol burns too hot and distorts or burns valves and piston rings etc. It may even seize your motor. Here is a list of real gasoline in Canada and the USA.http://pure-gas.org/
I have to turn power switch off then back on on my minimax NT , then service light will flash once blower comes on for 20 sec. then shuts off i have nothing. What part should i throw at it first
Any fault codes?
what about the flashing Red light?
how many times is it flashing quickly? It will pause between message/code of quick blinks.
To assist, more info needed.
Jun 02, 2015 | Pentair Minimax NT Heater
Out of time what do you do
Check the ignition module, timing gap and keyway on the flywheel. All 3 can effect the timing of the machine
Feb 26, 2013 | Stihl Br420c Magnum Leaf Blowers
The heater turns on for 20 seconds then shut off then the air flow swich blinks
either faulty air flow switch, blower not producing enough pressure, blockage in venting, blockage in air switch tubing
Jul 26, 2011 | Jandy Laars Lt 400,000 Btu Heater
My stihl BR420c blower loses power after running.
Try turning the high speed mixture screw out a quarter turn.
Mar 22, 2011 | Garden
I have a Ducane MPGA100B4B gas furnace. The furnace only runs for about a minute then shut off. It does this far too frequent.\r\n First the induce draft blower turned on for a few seconds to check for...
Hello, sounds like the limit switch is opening on the furnace.Usually when a furnace goes off on its high limit is becuase the airflow is being restricted making the furnace overheat. a limit switch is there to protect the furnaace from overheating, most cuases are either dirt or the blower motor not running up to speed, anything that cuts down on the airflow will cause the high limt switch to open.
Feb 24, 2011 | Heating & Cooling
My fireplace starts up just fine and after 15 seconds the blower and heat shut off but the flames are working fine. any ideas?
the fan on most fireplaces incerts and free standing is turned on by a click dics. if you see no change in your fire then chances are this switch is bad. follow the wires from the fan and you will fine this switch. there will be another one that protects from over heating so make sure you have the right switch if your comfortable jump the fan switch, 110volt, and if fan runs wala find a dealer and buy new switch.
Jan 27, 2011 | Heating & Cooling
I have a goodman mfg gmp100-4 furnace. When I turn theromsat to heat I hear blowing for sixty seconds but that is all that happens. What should I check first?
Your furnace has a combustion blower on it. If it runs and don't pull in the vacuum switch the furnace will not start. On the combustion blower you will find a little rubber hose follow that hose to the vacuum switch. You will see 2 wires on the vacuum switch connect the 2 wires on the vacuum switch together. If your furnace starts and runs fine for 15 to 20 minutes you need a new vacuum switch. Try this first
in this image A is vacuum switch B is combustion blower
Hope this helps......
Nov 16, 2010 | Goodman Heating & Cooling
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Stihl Br420c Magnum Logo
183 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
