Question about Kenmore Washing Machines
Kenmore dryer model 86681800 drum won't turn - Kenmore Washing Machines
SOURCE: kenmore 80 series dryer MODEL
Check your belt.
Posted on Jul 10, 2008
zeusfaber
  • 247 Answers
SOURCE: Kenmore clothes dryer model number
My instinct on this one is to look for a thermal cutout and to try to reset it.
Not familiar with the layout of the Kenmore 110's (they're not marketed in this part of the world), but a good place to start is probably inside the top of the machine.
Before fiddling, turn the power off and unplug the machine.
Look for a metal duct leading into the drum housing. This will probably have the blower mounted at one end, then the element embedded in it, then, before it leads into the drum housing, a collection of thermostats and safety cutouts (usually one or two of each) mounted on the outside of it.
Safety cutouts and thermostats are likely to look something like one of the pictures at http://www.tdspares.co.uk/products.asp?cat=68
Start by looking for cutouts with reset buttons - press the button on any you find and see if this fixes the problem. It's a good sign you've found the right one if it clicks when pressed.
If that doesn't work, use a multimeter to test across the contacts of each thermostat and cutout in turn. They should all have a very low resistance. reset or replace any that don't.
Once you've got the machine working again, you need to find out what made things trip and eliminate the underlying problem. This is usually a matter of cleaning all the accumulated lint out the machine.
Good luck.
A.
Posted on Sep 13, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore dryer drum does not turn Model 3389411
Some repair pix
Posted on Aug 28, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I have a Kenmore model 80 dryer. It turns on
Hello there:
Thisis caused by a belt that has either broke or the motor for the belt has failed i would remove the back panel of the dryer to axcess the motor and the belt and inspect to see if the belt has broke if not than i would have the motor checked out or there may be a capacitor for the motor that has failed.
If you feel that you can do the repairs i would suggest doing it cause you would save your self a lot of money doint it your self ok
Hope this is very helpful for you
Best regards michael
Posted on Dec 22, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My Kenmore Dryer, Mdl #86681800 won't start when hot
The most likely reason it that the electric motor is failing; the thermal protector on the motor is resetting after the motor cools down. The buzzing is due to a locked rotor in the motor while it is overheated.
Another much less likely possibility is that there is excessive drag on the drum causing the motor to overheat because it is working too hard spinning the drum. Excess drag is due to worn rollers, etc.
Try rotating the drum in the CORRECT direction by hand and see if it seems really hard to rotate. You can try this on a friend or relatives machine to see how much drag is normal.
To determine which way is the correct rotation, just start the dryer, open the door and look fast! To test, just turn it in the same direction as it was rotating before it stopped.
Mar 09, 2013 | Kenmore Dryers
Old kenmore dryer, drum won't turn
Could have the motor frozen, (armature,bearings,etc) causing an overload on the circuit. Can you physicly move the drum by reaching in and turning it?
Feb 12, 2013 | Kenmore Dryers
Kenmore dryer model 110.66722692 won't start
does the drum travel up and down losely. if so the spindle at the rear of the drum in the centre has worn and needs replacing
Dec 21, 2011 | Kenmore Dryers
Kenmore model # 86470810 buzzes when I press start but won't run
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch
Sep 21, 2011 | Kenmore Dryers
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
My kenmore model 1107020290 will heat but the drum will not turn
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 07, 2010 | Dryers
Washing Machines Logo
35 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
