Question about Invacare Full Electric Hospital Bed - IVC5410
Try to disassemble ivacare full electric Hosp. Bed
I need help disassembling an Ashley Zayley full size bed. There are 4 sets of screws that are holding the bed together but none of them will unscrew.
Screws in beds are designed to be quite tight, so that there's no movement, which would be quite aggravating to the person lying on it. Likely the constant movement has seated the screws even more firmly. I can only suggest better tools, or drilling them out.
Jun 16, 2017 | Baby Gear
Building a twin over full bunk bed
I would try looking at <a href="http://cedarshop.com/calgary-lumber-supply-products/">building materials in Calgary</a>. They helped me out a bunch when I made a treehouse.
Jul 18, 2013 | Furniture Imports B879UBS Cambridge Twin...
Ultramatic bed problem - bed will not raise either head or feet - does not move at all. Received replacement remote from company but no different. Lights on remote do not stay on - only when press a button...
Had same problem with my husbands moms bed. Found out that it ended up being a stripped plastic piece that the screw uses to raise and lower the bed. Because its stripped the screws don't have anything to grip on again to raise or lower bed. Piece needs replacing, but not sure where to get them.
Jan 12, 2011 | Minicraft Models Full Electric Bed -...
Have the genius ultramatic bed. Need to know how to reset?
My head of the bed went up all by itself, the remote had NO battery in it. How do I reset the remote to make the bed go down? It won't work with battery in..... Please advise asap, need to sleep tonight! Thanks
Dec 28, 2010 | Minicraft Models Full Electric Bed -...
The acme nut for the head of the bed is broken. How do I get a new part? Patty
Patty,
Thank you for your e-mail reply for clarification.
We can try to locate your part by description in a diagram.
A very popular full electric bed was made by Invacare and also Hard Manufacturing.
Let's try going to Invacare.com. Click on the following drop down menus.
Click on the tab, parts catalog:
parts category beds and TSS
Homecare beds manual, semi electric, full electric Careguard by Invacare
Bed ends full electric 5301 Low
If this looks like your assembly we are set and I can help you further.
If not we can call a company in New York called Hard Manufacturing.
If these two options don't work you may have to bring the bed end down to a local dealer and see if they can help. Please reply and I will help you further.
By the way, the manufacturer tag may be on or near the control junction box where the motors and hand control plugs in, possibly underneath on the frame.
Nov 13, 2010 | Health & Beauty
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
How to change a toolder bed into a full bed?
if it is white and metal contact me i own the same one and can walk you thru it
Jul 19, 2007 | Simplicity for Children 4-in-1 Convertible...
Invacare Full Electric Hospital Bed - IVC5410 Logo
926 people viewed this question
Top Invacare Medical Experts
Electro Med Services...
masud
masud
Rhonda Webster
Rhonda Webster
Are you an Invacare Medical Expert? Answer questions, earn points and help others
