Question about Car Audio & Video
Dual xpe2700 I'm not sure on how to setmy gain and frequency
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Theyre on the sides. its the large buttons. then you will need an oscilloscope to set frequency and gains properly without clipping.
get back to me when you get one.
Posted on Nov 15, 2013
Is dual band booster is supported for Australian mobile band network?
Yes, dual band booster is supported for Australian mobile band network. It can be used for an outdoor direction aerial or for indoor spaces like home. This is the same style aerial supplied comparing other network system. The antenna can be set in an all-weather casing. The high gain system panel is perfect for wall-mount applications. This antenna works the 850MHZ, 900 MHZ, 1800MHz and 3G 2100 system frequencies (Australia and NZ telephone arranges) and is good with most portable sponsor packs.
Mobile Phone Signal Booster Best Signal Repeaters in Australia
Apr 18, 2017 | Dual Cell Phones
AT&T 2230 2.4 GHz Dual Handset Cordless Phone - additional phones?
Hi yes you can add additional phones to it as long as their the same frequency so that they pick up the signal from the main phone that plugs into the phone line.
Im sure you can have upto 4 handsets but just make sure theis same make and frequency
Jan 29, 2008 | AT&T 2230 2.4 GHz Dual Handset Cordless...
My XPE2700 admits a light popping sound through the speaker, what might be the problem?
Motorboating is the name of the sound and it isn't common in modern equipment but has been common in older equipment. There are various causes for this low frequency oscillation.
There is plenty written about it so I suggest you google the subject...
Mar 26, 2017 | The Audio Players & Recorders
How to wire 2/1 channel XPE2700 in stereo/bridged mode?
for stereo wiring, you get the most power with dual 2 ohm loads, in mono, you want a single 4 ohm load, or 2x2 ohm loads
Jul 18, 2014 | Dual XPE2700 - 2/1-Channel 400-Watt...
Light not coming on
Is there power at the outlet socket? Check the power cord from the outlet socket to the amp.If the power indication light on the amp does come on the you will need to check the internal fuses.Some models have an external fuse located on the back panel
Apr 09, 2013 | Dual XPE2700 400w 2ch bridgeable amp
My amp is going into protection mode
Check all the wires that none of them come off,
Oct 28, 2012 | Dual XPE2700 - 2/1-Channel 400-Watt...
I have a dual xpe2700 amp and it wont power on and i have everyting hooked up
Firstly, there are some things you have to check.
Make sure that the battery or source of power has the required power to turn it on.
Also, make sure that the power cable is properly connected and is not broken or damaged.
If all of the above are checked and are in good order but it still won't power on, then it is Amp that is damaged.
In this case, you must send it to a technician to help you work on it and rectify any errors or issues.
Hope this was helpful?
Feb 13, 2011 | Car Audio & Video
I have a dual xpe2700 amplifier and it's connected correctly bit the little triangular shaped light won't turn blue like when it does when it on an idk what's wrong with it or what to do to make it work.
How are you certain that you have the amplifier connected properly??
1. 12 volt constant wire should be run directly to the car's battery. MAKE SURE WIRE IS FUSED PROPERLY WITHIN 10 INCHES OF THE BATTERY!!!!
2. Chassis ground wire can go to any heavy bolt close to where your amplifier is mounted.
3. Remote turn on lead comes from the radio harness.
I suspect that this wire may be missing in your case.
If all wires are connected properly AND you do not have a low voltage battery condition than your amp may be nothing more than a shiny paperweight now.
Dec 21, 2010 | Car Audio & Video
Pioneer Amp
Hello Shaun123, Phase adjust the amount of lag or lead one signal has in reference to another. Frequency is an adjustment of the number of cycles pers second a signal will produce. Gain refers to the amplification factor of a signal. now in reference to you amplifier by changing phase you can set the delay of a signal (if used right you can make a wicked reverb effect), but setting phase normally will affect the tones Frequency will affect for bass and treble functionality Gain will both preset and provide amplitude adjustment (volume) Take into mind these are more then likely presets. I hope this helps
Sep 05, 2007 | Pioneer GM-7200M Car Audio Amplifier
Alpine pdx 1.1000 amp
These subs are dual voice coil I'm sure...make sure they are putting a 2 ohm load on the amp total, and also set your gain and frequency setting right. Set the frequency around 85 or 90, make sure the lo pass filter is on. Turn the gain ALL the way down and turn your stereo to the point right before your speakers distort....then slowly increase the gain until the subs are playing at full volume. This should not even be close to all the way up, and the subs should sound accurate and bold. Turning them past this point will cause distortion, in which case you should back off the gain a bit. Distortion causes power to cycle through the amp very rapidly and can cause blown subs and blown fuses. If you do not know how to wire both subs for a combined load of 2 ohms, please let me know what type of subs you have.
Aug 05, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
