Question about Refrigerators
I have a samsung refrigerator the RF26V series and it is not making ice. Have water but no ice.
3 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: freezer went crazy!!! help
I'm sorry but I cannot find an RF26V model could you double check the model? Sea Breeze
Posted on Nov 26, 2009
  • 884 Answers
SOURCE: samsung refrigerator rf26v ice maker
Check the condenser is clean and clear. Remove all fluff, dust or dirt from under and behind the unit
Posted on Apr 23, 2012
I have Samsung refrigerator RFG298 series the ice maker stopped working and sounds like a dog barking when it's running any ideas what it could be ?
Possibly the gear drive faulty in the ice maker, or it could be the dispensing chute has ice blocking it from closing properly. Completely empty the ice tray and make sure there is no ice anywhere in the tray, guides or ejection chute to the front door. On some, there is a little button under the icemaker for testing and forcing an ice maker operation. Press it and see if the ice tray rotates and reloads with water.
Nov 20, 2016 | Samsung RFG298HDWP French Door...
My Samsung RS2556BB refrigerator ice maker is not making ice anymore. The freezer still very cold but there is no water coming into the ice tray. I switched the relay in the back and pressed the water...
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Samsung RS2556 Side by Side Refrigerator
Rfg297aa won't make ice
Ice maker quit making ice. Ice tray in feeder was empty when I pulled it out. Water is working when I choose water but apparently no water is getting to freezer unit. What else can I check or do?
Oct 28, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung refrigerator rf26v ice maker
Apr 23, 2012 | Samsung RF26VAB (25.5 cu. ft.)...
Freezer went crazy!!! help
Nov 26, 2009 | Samsung Refrigerators
Frozen ice tray Samsung noit making ice
I had a similar problem. It had to do with water pressure. When I put in a new water line tap, it increased the pressure and has made ice perfectly since. I had to use a blow dryer to thaw
Jun 25, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs2555sl ice maker trouble
check to make sure that the tube that fills the ice maker is not froozen upo and causoing this problem
Feb 21, 2009 | Samsung RS2556 Side by Side Refrigerator
Ice Maker problem
There is a water valve that "feeds" the ice maker. When the Ice maker makes ice it sends a signal to the water valve, it opens for approx. 7 seconds and fills ice tray with water. Another cause of no water in IM could be frozen water line where it feeds the IM.
Mar 19, 2008 | Samsung RS2578BB Side by Side Refrigerator
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
