Question about Watches
Skagen watch date won't automatically change.
  • 29 Answers
That sounds like a bad circut so you are going to need a service. Should cost between $50-$100 therefore you may want to consider replaceing it as the repair costs would be close to the replacement costs.
Posted on Jan 01, 2014
escapement
  • 2334 Answers
SOURCE: Lost screw to secure watch band on Skagen 355LGSC
You just have to to see the watchmaker. As all watch band screws are made to particular bracelet, it's allmost impossible to find the right one if you are not in watch repair business. It will not cost too much and will save your time and nerves if you'll ask the watchmaker.
Find your nearest watchmaker and ask for help.
Posted on Dec 22, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
escapement
  • 2334 Answers
SOURCE: directions to change day and date on old bucherer automatic watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
  • 103 Answers
SOURCE: replacement battery for Skagen 430SSXD watch
send your watch into skagen since you have a lifetime warranty you do not want to breech that. plus they reseal your watch and other watch repair places cant.
http://www.skagen.com/service/home.fx
Posted on Aug 04, 2010
  • 103 Answers
SOURCE: Watch battery and manual for Skagen 271sgxd
try sending it to skagen they can fix your watch and you will still be covered under there lifetime warranty!
http://www.skagen.com/service/watchWarranty.fx
p.s. the manuals are all on this site as well!! thanks!
How to set the date
http://webprojectng.com/library/s/skagen-355lgsc-watches-owners-manual.pdf
Mar 18, 2015 | Skagen 355lgsc Steel Mens Watch
Just got a new Seiko watch but the date won't change automatically
Main cause would be that the date gear teeth have been stripped. This is done by setting the date whilst the hands are trying to change the date themselves (between 10pm and 2am). Always adjust the date with the hands around 6.0clock. You will need to return your watch to where you bought it for repair I'm afraid.
Jan 18, 2013 | Seiko watch - SXDA42 Watches SXDA42 Ladies
433LSLB stops working, sometimes overnight,
send it into skagen it has a lifetime warranty
http://www.skagen.com/service/orderWatchBandParts.fx
Aug 05, 2009 | Skagen 433LSLB Wrist Watch
Skagen watch glasses keep cracking
Yes I would speak to Skagen in stron terms, this should not happen and wa probably aused by the glass being stressed when fitting it
Jun 18, 2009 | Skagen 170LTTM Wrist Watch
How to reset date on skagen watch, model 180LSLW
the stem pulls out three different heights, one is month, one is day, the other is time
May 15, 2009 | Skagen Men's - PERFORMANCE MULTIFUNCTION...
Set date on skagen 496sgsc
I used to sell Skagen watches,don't know excatly which watch you have . I even went to their web site and couldn't find it. Most Skagens ( unless they are a chronograph with the three curcles on the dial) works like this: Your watch stem has 3 differant settings #1 all the way in #2 half way out , and #3 all the way out . To set the time you pull the stem all the way out and adjust the time. To set the date,pull the stem all the way out and turn untill the date changes ( this will make sure you have it on am-pm correctly) then put the hands at 6 o'clock. Put the stem all the way back in, then pull the stem half-way out. Start with the stem all the way in and slowly pull it out and you will feel the "click" when it is half-way out. MAKE SURE YOU HANDS ARE NOT BETWEEN 9 O'CLOCK AND 3 O'CLOCK, OR YOU WILL BREAK THE AUTOMATC DATE SETTING GEAR!!!!! Then either turn the stem clock-wise , or counter clock-wise , one of the two ways will set your date.
Oct 27, 2008 | Skagen Watches
HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Nov 18, 2007 | Skagen 355LSSM Wrist Watch
Watches Logo
42 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
