Question about Bosch Dishwashers
Model SHU3036UC/U12 Won't advance to end of cycle
  • 1003 Answers
SOURCE: ...dead
CHECK DOOR SAFTEY SWITCH OR TIMER MOST LIKE SWITCH ASSOCIATED WHEN DOOR IS CLOSED
Posted on Jan 18, 2008
SOURCE: bosch dishwaher shu 4322 uc/u12
remove outer door skin and kick plate at base pump will be on view turn off power look carefully at pump you will see a lever you have to cut away a small section of plastic on lever to be able to push it inwards pump then twists off anticlockwise is a bayonet fitting like a light bulb.
hope this helps
Posted on Jan 23, 2008
here2helpBSH
  • 27 Answers
SOURCE: Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
Posted on May 30, 2009
  • 561 Answers
SOURCE: Bosch Model shu9925uc/u12 not draining throughout
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Posted on Dec 12, 2010
Daniel S
  • 4323 Answers
SOURCE: Dear sir In an attempt to
Hi
Check this video and clean the drain pump assembly:
After this if the issue returns then it seems to be a problem with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 12, 2011
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
My dryer quit heating and at the same time does not stop at the end of the cycle. Just keeps running. Is there something I can do to fix this problem?
If its on automatic cycle the timer won't advance if theres no heat. It will advance on timed cycle, though.
Sep 21, 2011 | Kenmore Dryers
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Bosch shu3036uc gets stuck during cycles.
Welcome to FixYa.
Based on your description " bosch shu3036uc gets stuck during cycles
I suspect the thermostat isn't satisfied when heating the water, hence it get`s hung up trying to heat in the part`s of the cycle it`s called for.
It very well could be caused by a faulty flow switch, NTC or heater as well but not very likely.
The dishwashers made by Bosch with a rotary dial timer have very few if any, issues with the actual timer or element but they do with the thermostat within the door panel.
If it ( the thermostat ) is not satisfied the water may heat but not be indicated via the thermostat, hence timer will not advance.
Here`s what you can try. If you have any hesitation or reluctance to service this yourself please call in an authorized B/S/H/ ( Bosch/Thermador/Gaggenau ) appliance technician.
**Turn off the breaker at the service panel before attempting any service suggested **
  1. You will require a #20 torx screwdriver to remove the door panel by taking out the screws around the panel, except the ones along the top ( watch the edges they are very sharp )
  2. Once the panel is removed you should see the thermostat over by the detergent dispenser clipped to the inner door, remove it and test it. You`ll need a ohm meter/multi-meter plus a lighter or match to heat it up to see if it open`s & closes.
Example...
**NOTE** it can occur the thermostat can become loose and detach from the bracket which holds it in place, this too can manifest in the sysmptom of the timer not advancing.
Let me know how you make out and what you find.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Oct 31, 2010 | Bosch SHU3036UC Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
May 28, 2009 | Bosch SHU3036UC Dishwasher
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Very long cycle time for Bosch DW
There is a recall on the control board of many of these models, butyour problem is likely not related. I have written a guide to help. It is here. Thanks!
Jan 05, 2009 | Bosch SHU3036UC Dishwasher
Tried to replace bosch soap dispenser model shu3036uc/u12
Wire positioning doesn’t matter to soap dispenser. If water is leaking from the door then the dispenser is not pressed in properly against its seal. As far as the door not opening if wires are connected perhaps the problem is in the control module. Voltage meter on wiring to dispenser should indicate this while machine is running at start of quick wash cycle. (First 5 minutes of cycle on heating)
Dec 28, 2017 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
...dead
Jan 17, 2008 | Bosch 23 in. SHU303 Built-in Dishwasher
Dishwashers Logo
106 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
