Question about Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2
How do I drain an h250fdn heater - Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2
  • 128 Answers
There is a drain plug on the inlet/outlet header.
Posted on Nov 02, 2013
Why does my hayward h250fd have and if error code? it is a brand new heater
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
There are a few reasons that this might be happening. They range from air in the gas line to inadequate gas flow. Start by checking the installation
Aug 08, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Hayward H250FDN blue temperature control will not respond (MODE and RED up button are OK)
up and down button at same time with either mode or enter at same time for seven seconds that should unlock
May 16, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Is there an alternative control panel I could use for a H259FDN?
Unless you have rigged your unit for remote control, this control panel is the only one listed.
You can check this link for contact information
http://www.hayward-pool.com/prd/In-Ground-Pool-Heaters-Universal-H-Series-Low-NOx_10201_10551_14002_-1_14003__I.htm
May 12, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
When heater is running smell way to much gas
have gas pressure checked if ok check pressure on back side of gas valve also check connections after gas valve
Aug 15, 2013 | Hayward H250FDN Low NOx Natural Gas Pool...
I want to go over 104 degrees
cannot just can go to calibration and cheat 4 degrees
Jan 12, 2012 | Hayward H250FDN Low NOx Natural Gas Pool...
Header cracked on hayward pool lo nox h250fdn heater. need to replace the header. Please help?!
Headers on hayward heaters are usually warranted for 10 years, except for freeze or chemical damage. You may want to contact a local warranty station to see if you can get it replaced under warranty.
May 07, 2010 | Hayward H250FDN Low NOx Natural Gas Pool...
Heater is new, installed at grade on above ground pool that is 48" deep so pressure switch is 3' below the water line. With pressure switch adjustment turned fully clockwise the heater will run without the...
Adjust the switch fully in the opposite direction. If you are at 1.5 you are at the light end of the adjustment range of that switch, which can be adjusted up to 5psi. Then let it back off until it works reliably. Rarely do you need to adjust a pressure switch on an above ground pool so it should end up about in the middle of the adjustment scale.
Jul 09, 2009 | Hayward H250FDN Low NOx Natural Gas Pool...
Hayward H Series Electronic Ignition 250,000 Btu Pool Heater  H250ped2 Logo
52 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
