Question about Astoria JADA AK SUPER Espresso Machine
I keep getting the error "Piston Motor GR1 Blocked" what does this mean and how do I fix it?
Check number 3 micro switch on group 1 or check the timing if it ok
Posted on Sep 28, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Diss-asemble the piston and un-block it .
Posted on Nov 02, 2013
PT cruiser oil spraying in cylinders why
Please share how you are getting inside the cylinders to see oil spraying inside whilst the motor is running?
Give us a whole lot more information, perhaps we can help.
God bless your efforts.
Jan 23, 2017 | Chrysler PT Cruiser Cars & Trucks
Motor keeps blowing left piston, i assume its sucking air in somewhere , but cant figure out where or if that is the problem forsure!
if carbs, check main jet, if partially blocked it will run weak as hell as more air than fuel gets in,
Feb 11, 2015 | Motorcycles
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
I keep getting an F35 error. I drain and spin and try again, but keep getting this error and then the machine stops.
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code 11 on a Rinnai energysaver 556FTR
Rachel,
The 11 code means Missed Ignition. This is a broad error code. It just means the stove did not light when it was supposed to. I would check the fuel first to be sure the valve is on and you have gas. Next, try to start the stove with the room dark. Look into the window to confirm a sparking. This is the igniter. At the same time be sure the combustion motor is running. You should be able to hear it and feel the stove to confirm this. If the motor does not turn or the flue is blocked you will not get any gas to flow. Look outside to confirm the flue is not blocked.
Keep us posted,
Tom
May 29, 2010 | Rinnai EnergySaver 556 Air Conditioner
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
Astoria JADA AK SUPER Espresso Machine Logo
123 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
