Question about Toshiba TP61F80 61 in. Rear Projection Television
Toshiba TP61F80 Projection TV
Unit will not power up. The power LED flashes (with no pattern, just a constant blinking)with any attempt to turn the TV on. Unpluged it to reset any relays and when plugged back in relays energize and then a second set of relays click or the first one closes. Any Ideas? ? ? testing the red, green, and blue drive boards now.
Wrong. Green color gun board "- control voltage rail" cold solder joint. Then a re-alignment. Got a few leaky caps in the mix too. But I'll do that later. Thanks for the help! ! ! GREAT site still.
Posted on Oct 01, 2007
    Genius:
  • 1,694 Answers
Check power supply for open micro fuse{s}-- If the fuses for the convergence circuits B+ are open,replace convergence IC,s and fuse devices.Then perform re-alignment in servicer mode.test run.Don't forget--PVAT! solder any/all bad connections.
Posted on Sep 28, 2007
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
I have a Toshiba TP61F80, i have had the tv for little less than a year. It is a GREAT tv I love it. My tv is plugged into my home stereo so when i power that on tv turns on as well. I pushed the power...
Try unplugging the unit for 10 minutes, then plug back in and try it. If the unit just has a fault this will reset it and it should work. If it does not solve your problem I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which explains the troubleshooting process and should help you isolate the problem. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 21, 2010 | Toshiba TP61F80 61 in. Rear Projection...
Red power light flashing; will not turn on.
It is very likely that one of the convergence correction chips has gone south on you (either that or a capacitor). What you want to look for is a swollen capacitor , or a burnt resistor near the two large heatsinks on the signal/convergence PCB. The flashing LED is an indication that the power supply has detected a fault, your mission is to determine what that might be. another thing to check out at the fuses on the power supply PCB (these have labels like FXXX were XXX is a number). If you find an open fuse, that will help determine where to look for the fault.
Jun 18, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 27, 2009 | Toshiba 50HX81 50" Rear Projection...
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Sony Projection Tv Model KP-51HW40
With both of error codes flashing, the problem is trying to figure out wich one to focus on. The flashing 6 code is an indication of HV failure which would then cause a vertical failure(4 blink code). There are so many things that would cause this problem. I can narrow it down to the "D" board to fix your problem. If I were there to troubleshoot it, I could narrow it down further I.E. flyback, HV distribution block. I suggest getting a tech diagnose the exact problem. I wish I could narrow it down better for you. Please take time to rate this solution and if I can be of further assistance, let me know
Dec 13, 2008 | Sony KP-51HW40 51" Rear Projection...
Toshiba 57h81 red light blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
Red light blinking on power button. won't turn on.
need to know the model and if it blinks a certain number of times with a pause then blinking again.
Apr 11, 2008 | Televison & Video
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
180 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
