Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Isuzu elf starter problems - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
How to time rotory injector pump on isuzu elf hf1 engine
you asked 4 times
why
this is USA car forum not ELF heavy trucks.
why not post to your country forum on ELF or buy the book
at your dealer.
Mar 29, 2017 | Isuzu Cars & Trucks
Need a vacuum routing diagram for an isuzu elf 1998 model truck
Heavy truck, ELF>
is car USA< this is a USA forum.
and our smog parts are not like YOURs, if not here.
no engine stated.
no country stated.
in the USA even california has there own laws on EGR, and more.
so it be impossible to answer you.
its not as simple as you think, sorry
Jul 24, 2016 | Isuzu Cars & Trucks
What is the torque spec on 98 isuzu npr front wheels
Julie
what year NPR 1998
what weight class.?
if not sure post a photo of the beast. !
sorry not all NPRs are the same, not EVEN close.
so not listen to the net rumors, why trust your life to rumors>?
read this, (where are you?)
The fifth generation Isuzu Elf appeared in July 1993, with more sculpted headlights.
In May 1995 it received a minor change, including upgraded, cleaner diesel engines.
An OEM deal with Nissan led to the Elf also being sold badged as a Nissan Atlas and a Nissan Diesel Condor 20/30/35 beginning at this time, followed by the Nissan Atlas Max from 1996 until 2000. The Atlas Max was based on the new, lighter duty Elf 100 (June 1995) which was available with a 2-liter petrol or a 2.5 or 2.7-liter diesel engine.[20]
In May 2004, subsequent to a few minor changes, the Elf underwent a more major facelifts with new, larger, trapezoidal headlamps.
Another OEM deal was forged at this time and the Elf was now also marketed as a Mazda Titan in parallel.
In Malaysia, this truck is manufactured by Heavy Industries Corporation of Malaysia (Isuzu HICOM Malaysia) under the name of HICOM Perkasa, but carrying the Isuzu N-Series Commando badge.
? 100ft/lbs is a good guess, but is but a guess.
Jun 27, 2016 | Isuzu Cars & Trucks
Reseting timing belt check light for isuzu elf 150 diseal manual
no year stated, (gee first question in all books is, year)
1959 to present...
then what car (ELF ) then what engine. using real names.
what is the question,?
try to form clear distinct question, please.
so a job stated, cam belt new.
what does check light mean? (the engine check light is unhappy?)
my guess is huge truck ELF.
stick shift manual trans. ok
not gl150 petrol
diesel.
gen 4 ELF 150, is not and engine
its; these.
KAD42/52, TLD23 C240, diesel I4 2369 cc 74 54 3800 Elf 150 Super, Elf 250
the year, and what engine, makes most answers easy.
a cylinder>?
https://en.wikipedia.org/wiki/List_of_Isuzu_engines#G161
here is just a guess at the first ELF150. engine option
there are many more.
Dec 30, 2015 | Isuzu Cars & Trucks
Elf 4bc2 engine. how do I set injection pump timing?
4bc2 . ELF truck?
e 4BC2 is a 3.3 L direct injection diesel (otherwise the same as the 4BC1) sold in the Isuzu ELF and NPR trucks from 1982 to 1987
what year
what country?
i guess you think all engines work same in all countries and years?
wow.
did you ask ISUZU first? that be first. right, a book on your heavy truck.
finding free books in this truck, is hard, i gave up.
Dec 17, 2015 | Isuzu Cars & Trucks
What is the valve clearance of isuzu 4ba1?
The 4BA1 is a 2.8 L (2,775 cc) diesel sold in Isuzu Elf light trucks of several generations
what year, and in what car? or truck?
this is a USA forum and we dont have elfs, here, im guessing elf.
did you goggle first.?
here ill do that for you.
https://www.google.com/webhp?gws_rd=ssl#q=++isuzu+4ba1+valve+clearance
see all those hits, read em?
May 17, 2015 | Isuzu Cars & Trucks
What is the valve clearance settings for the Isuzu elf 150 with 4jg2 engine
no year, are you kidding? joking?
if it has it at all, its covered in the FSM.
this is USA site, no ELF'S here, sorry.
i looked with google for you , its a vacuum on that engine.
but many be google does better in your country , unstated. so...
for sure, go to ISUZU dealer, parts counter and say this.
can i buy the" Factory service manual for my car? zzz"
Jan 24, 2015 | Isuzu Cars & Trucks
I have isuzu elf fire engine local mentinence department cut down the ecc box timer that's why i need electric diagram.
motor swap>?
Problem with 1993 Toyota Supra I have isuzu elf fire engine local mentinence department cut down the ecc box timer that's why i need electric diagram.
Jan 17, 2014 | 1993 Toyota Supra
1988-1992 12V or 24V
Isuzu models sold in the US are all 12 volt. I am assuming your vehicle is from another country if it is 24 volt.
Aug 23, 2012 | 1988 Isuzu Trooper 2 Door
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
27 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
