Question about Northstar ETQ DG6LE Portable Generator GG0160 Diesel 6000 Surge Watts 120/240V 1 Phase 41.6/20.5 Amps OUTPUT ETQ Engine 8.85 HP
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak in the fuel tank last week. It is seeping on the seam where the upper and lower halves of the tank are put together. Although this was obviously a manufacturing defect the unit is slightly over a year old and out of warranty. Any suggestion how I might fix it?
    Master:
  • 342 Answers
Remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Posted on Nov 04, 2013
3 Suggested Answers
SOURCE: Fuel pet **** came loose from fuel tank...
It's a rubber grommet available from eReplacement Parts for $1.84. Part # GS-0446.
Their link is ereplacementparts.com
Phone: 866-802-6383
I just got a new one for my tank. Had to order 3 as they have a $5.00 minimum order.
Posted on Aug 17, 2009
stewbison
  • 577 Answers
SOURCE: I have a 5500 ppg
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Posted on Sep 29, 2011
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
Where can I find a service center in Pasadena, TX or Houston, TX????
YOU CAN FIND OUT ON THE YP (YELLOW PAGES) LOCALLY AND ON THE INTERNET YP.COM
Jun 17, 2015 | Northstar ETQ DG6LE Portable Generator...
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ 4000. New carb, new plug. Will only start with starter fluid then die.
You know you have ignition. It isn't getting correct fuel. CHeck fuel to carb. If confirmed fuel to carb, carb is not adjusted properly.
Jan 08, 2015 | ETQ 4000 Watt Generator
Where is the muffler and exhaust on ETQ prtable generator?
The exhaust will be located on the output side of the cylinder manifold.
Sep 01, 2014 | Eastern Tools & Equipment ETQ Tg72k12 8250...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
2002 ford thunderbird water leaking onto floor
If you've got wet spot on the passenger side floor area, it is *probably* a leaking heater core. If the wet spot is an antifreeze / water mix - it is almost certainly a leaking heater core, since it is located behind the dash in this area. A leaking heater core problem can be expensive to repair - as it is difficult to access. Replacement drives the price higher still.
If is is fresh water, it may be a leaking windshield seal. An auto glass shop should be able to fix this for you for a lot less than the heater core repair.
I hope this helps and good luck!
Sep 29, 2011 | Maytag MZD2766GES Side by Side...
I HAVE A ETQ 1200 GENERATOR I NEED ON THE
The pdf for this generator is available at easterntools.com
Feb 07, 2010 | Eastern Tools And Equipment 1200 Watt...
Whirlpool Duet Frontloader Destroyed my home!!!!!!!!!
Are you kidding? You don't notice an odor or anything else other than a wet spot once that you thought your dog had an accident? Why is that Whirlpools fault? You have your due diligence to make sure if something is wet than there has to be a reason why something is wet. Besides, if you have that much black mold than there must have been some other signs of water than just that once.
Dec 15, 2007 | Whirlpool GHW9150 Front Load Washer
Northstar ETQ DG6LE Portable Generator GG0160 Diesel 6000 Surge Watts 120/240V 1 Phase 41.6/20.5 Amps OUTPUT ETQ Engine 8.85 HP Logo
131 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
 Generator Guru...
Generator Guru...
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
