Question about GE GSS25LGM Side by Side Refrigerator
Refrigerator stopped cooling, I checked the back and fan was running and so was the compressor. I blow out all the lint and checked all the electrical connections, took about an hour or so. I plugged it back in and in about 2 1/2 hour or so the freezer was getting down to about 1 degree at setting #6 the frig. side was at 40 degrees. By the next morning it was still running but temp was 40 degrees on both sides and thawing. where do I go from here?
  • GE Master
  • 3,498 Answers
Hey Anon,
Sounds like you may be low on freon... call a service tech.., the local mom and pops stores usually help more than the big ones..
Posted on Jun 22, 2017
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website
Posted on Sep 25, 2007
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
  • 1304 Answers
SOURCE: freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Posted on Oct 14, 2009
Testimonial: "it seems that even if I set the control to the coldest is dosen't affect the temps range"
Sea Breeze
  • 4655 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
  • 4070 Answers
SOURCE: My GE profile side by side frig goes into defrost
. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Posted on Mar 08, 2011
Testimonial: " "
My lg gm-313sc keep on work and stop in lest than 3 minits
The refrigeration is short cycling. The cause may be due to airflow problem. There is an outside fan thalt blows across a radiator and another in the inside the fridge enclosed behind panels.
These two fans must run and blow across the refrigeration radiators. The outside one can clog with lint and dirt, the inside one can clog with ice buid up, or the fans simply quit working. Check that the fans run and that the radiator coils are clean and clear to airflow. For the outside one, paneling will need to be removed, as well for the inside one if the outside one does not do the trick.
The refrigerator compressor short cycles because it overheats. The cool refrigeration gas entering the compressor cools it and when the gas is not kept cool, the compressor may short cycle.
There may be a different problem but checking for airflow is a start.
Jan 06, 2015 | LG Refrigerators
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Amana side by side freezer not cooling enought
With so little information all I can say is check to see if the coils underneath the refrigerator or in back behind the cover are blocked with lint or the fan is running that draws air across these coils and cools the compressor is running. Check to see if there is frost building up in the freezer on the back panel. If so then you have a defrost issue. This could be caused from a bad defrost timer control, a bad defrost heater or defrost thermostat. also check to see if the freezer fan is blowing. There could be a bad thermostat that controls the cooling it may be shutting off too soon. Check the door gaskets around the freezer and fresh food sections. If they are torn you could be losing cool air and drawing in warm air. There are so many things that could cause a poor cooling condition. All is usually fixable but the worst case scenario is a weak compressor. lets hope this is not the case.
I hope this helps.
May 25, 2014 | Jenn-Air JCD2389G Side by Side...
Refrigerator not cooling properly
There are several things that can cause cooling problem with your refridgerator. The first and most common is dirt dust and lint clogging the condenser coils. These coils are usually located underneath the refridgerator and have a small fan that blows air across them. If they are clogged, the refridgerator cannot get rid of the heat to allow it to cool properly. To check and clean these coils you must first pull out the refridgerator and unplug it. Remove the lower panel ( usually made of a cardboard material) this will give you access to the compressor and fan and coils. Check the coils for dust,dirt and lint. Clean out carefully with a vacuum cleaner or brush( you can get a brush specially made for this ) check the fan motor to see if it spins freely( some units may not have a fan) plug unit in to see if fan runs (make sure to temporarily turn thermostat down colder to turn on compressor and fan). If fan does not come on with compressor you may need to replace it. Put unit back in place and see if that solves the problem. If this does not help, you will probably have to have a appliance repairman check out unit.Hope this helps.
Dec 15, 2013 | Maytag Refrigerators
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Hot spots on outside of Amana fridge. sxd22s2w model
if it feels like it's running hot check the coil to see if it needs to be cleaned,remove the bottom kick plate and look at the coil,the coil should be cleaned once every 6 to 12 months,also pull the fridge out,remove the back bottom panel,make sure the condenser fan is blowing and vac out any lint near the fan and compressor,also check the cover that you removed and clean that might want to unplug the fridge while you clean back there so you don't hit the fan blade,wait 5 minutes before you plug it back in so the compressor can reset itself.there are gas lines that run through the frame of the machine,if the coil is jammed with dust and lint the machine runs hotter,this is how it cools off through the condenser coil and the fan blows the air around to help cool it down,if it runs hot then the freon will run hot and you could feel it on the frame and in the strip where the doors close can buy a brush that you can push into the holes of the coil to pull the dust out or if you have a shop vac you can vac out as much as you can and then put it on blow and blow the dust out of the coil,just hit it with short bursts or the dust will blow everywhere.
May 22, 2011 | Amana Refrigerators
Whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Nov 12, 2009 | Whirlpool ED5FHEXMQ Side by Side...
My refrigerator stopped cooling even though it is runing
By running I assume you are saying the compressor (underneath the refrigerator) is running.
You should also make certain that: (1) the compressor fan (near the compressor near the back of the refrigerator) is running; (2) that the refrigerant coils are clean; and (3) that the evaporator fan (inside the refrigerator, likely behind an access plate) is running.
Oct 22, 2009 | Refrigerators
I have hss25gfp side by side the freezer stopped freezing and it very hot on the middle divider. I took off the bottom on the back and it was caked with a bunch of lint. I cleaned it off. But noticed the...
If the compressor is running the condenser fan should be too. If the fan does not run the compressor will overheat and stop. If you cool the underside with a small box fan and the chill returns to the box, replace the condenser fan.
May 29, 2009 | Hotpoint HSS25GFP Side by Side...
Side by side fridge not cooling properly
If you have NO water in ice maker... check to see if inlet water valve to ice maker is still good.
Frig not cooling...
Look in freezer see if any frost build up, on back wall ..make sure fan in freezer is blowing.. also fan in back by compressor
Jun 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GSS25LGM Side by Side Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
