Question about Daewoo Washing Machines
Water not pump out properly
The machine run the spin process but the cloth is still wet. After take out the cloth, the tub fill with little water. I use cloth to wipe away the water but eventually the water will come out again.
    Master:
  • 818 Answers
You have a leaking water supply valve-this can be found right wher you attach the supply hoses-Cheers Denny
Posted on Oct 23, 2013
jsrock516
  • 5911 Answers
SOURCE: Loud clicking noise at spin cycle
It sounds like you have a motor coupling that has gone bad. Most of the Kenmore top loaders that I'm familiar with are direct drive machines. Which means, they use a motor coupling between the electric drive motor and transmission to run. If you are in the habit of doing heavy loads like comforters, blankets and jeans this can put a heavy burden on the motor coupler and wear it out faster. The coupler is designed to take the burden of the punishment in order to protect the transmission and drive motor and it is common for them to wear out. The coupler is fairly easy to replace and usually runs about $15. It is located inside the machine between the drive motor and transmission under the wash tub. You would have to remove the outside machine casing, the water pump and drive motor to get to it, though. Make sure the machine is unplugged before attempting any repairs involving removal of the drive motor. If you are not mechanically inclined, you may want to seek the aid of a repairman. I hope this helps.
Posted on Apr 29, 2007
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
  • 22 Answers
SOURCE: Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
Posted on Oct 21, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
SOURCE: water wont empty from machine.not spinning
Hi pauabreen
On the spin cycles (F or J) does your motor attempt to 'spin' up for about a second then basically fail.
Declan
Posted on Dec 20, 2010
My dishwasher won't empty
This condition is commonly caused by:
- Drain pump jammed
When you wash your clothes, any small objects (e.g. hair pins, coins etc) are flushed down the drain pipe but often get jammed in the drain pumps impellar (this is the tiny propeller on the pump).
Firstly, place a bucket on the floor....then lower your drain hose (from your tub) into the bucket - the gravity will naturally drain the water into the bucket. Be careful to raise the hose and empty the bucket each time, until the machine is empty. Remove any wet clothes from machine (you will need the bowl to be emptied).
Once empty, you can now check the drain pump.
Turn the machin off at the power.
Locate the drain pump cover (usually near the drain hose, on the back or side). Place a large towel on the floor beneath the pump cover (as remaining water will escape onto the floor). Unscrew the drain pump cover and allow the water to drain (if your pump cover contains a filter, then clean everything from this filter).
Then, look inside the drain pump cavity for anything obstructing the little propeller (remove any objects). Insert your finger inside the cavity and rotate the little propeller - you should feel a resistance, similar to a rubber band.
Re-install the drain pump cover (or filter) and ensure it is sealed properly. Turn ON at the wall.
Fill your bucket with water (from tub) and pour into your machine.
Turn machine ON, and select the last SPIN (or drain) cycle and check if machine now drains correctly. If ok, then problem now solved and you can put the clothes back into the machine for a final rinse/spin.
If machine still not draining after inspecting the drain pump, then you may have a suspected faulty drain pump - a technician can run a diagnostic process on your machine's control pad to find the diagnostic codes.
Please do let me know, if the above process helps you solve this.
Cheers,
Oct 02, 2011 | Dishwashers
Spin cycle is not getting clothes completely dry, can still hand ring water from clothing
When the clothes are wet at the end of a cycle, check these: Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 01, 2010 | Maytag Washing Machines
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Clothes are sill soaking wet after sin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Aug 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
Machine won't rinse or spin properly..also stinks!
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 08, 2009 | Maytag HAV2557 Top Load Washer
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Apr 01, 2009 | Bosch Washing Machines
10yr whirlpool toploader wash machine no spin/agitat. but works?
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Jan 08, 2009 | Whirlpool Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
