I HAVE A HEIL MODEL NTC5075BFC1 FURNACE, THE IGNITOR IS NOT GLOWING
  • 65 Answers
2 Suggested Answers
  • 27 Answers
SOURCE: Have a Heil Quaker NUGK080AG02 80,000BTU Furnace w/serial # NUGK 080AG02. The Ignitor lights the pilot but then fails to cut out (shut off etc.) once the pilot has been lit. What is the most likely
Probably your flue isn't clear enough.
Try blowing it out, you might have to remove a cover to do it.
Otherwise it may be the flue passage detector needs replacing.
Posted on Nov 18, 2013
Gas valve clicks when furnace is running
is there a second call for a flame on during the heat cycle..it may be worn out or the signal to open is not strong enough..
Jan 08, 2014 | Honeywell Icp Heil Tempstar Furnace Spark...
Heil furnace lights but wont stay lit 1990 model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 04, 2011 | Honeywell International Heil Quaker...
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
We recently purchased a home with a heil furnace and I need to know what size filter it requires. It is a gas heil model # NUG1075DF01. Please help !
That is hard to answer but I would say that for a furnace of that size you are probably looking at somewhere around 16x20x1. On older heil furnaces they often had the filter mounted inside the blower compartment so if the case you can just remove the cover and measure it. If not it should be located on the return air duct close to the furnace. Hope this helps you some. Thank you.
Dec 30, 2010 | Water Heaters
The heil furnance ignitor module error code
Remove the cover from the control box,there's a guide posted inside to trouble shoot the codes.
Jan 02, 2010 | Cross Furnace Draft Inducer Blower 115...
16 year old Heil 75K btu furnace, some times does not ignite.
recommend getting a carbon monoxide indictor or having some one test it. with it being over 15 yrs old if checks good replace ignitor assy should fix it ok
Dec 14, 2008 | Cross Furnace Draft Inducer Blower 115...
Furnace will not come on but thermostat is showing information
turn off power to furnace and open the front panel and see if you can see burners and gas valve and Hot surface ignitor.
If you can. turn furnace on and watch to see if the ignitor glows.
Let me know what you find. If it doesn't glow you probably have a faulty Hot surface ignitor.
If I had make and model number I should be able to find the part
Nov 16, 2008 | Honeywell Electronic Programmable...
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
