Question about Wahl Super Taper Hair Clipper 2000 Hair Trimmer
I have a WAHL 9757.I love it.It was bought for my dog but he does not need to be cut more than twice a year and I would like to cut my own hair with it .I would sterilize and clean it naturally.I would like to buy combs for it. Does it require a special set?
Micromax x211 mic jumper
Posted on Oct 23, 2013
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Posted on Oct 14, 2008
  • 3 Answers
SOURCE: wahl 9765-301
sounds like you have very dull blades and need to replace or sharpen them also your blades may not be tight enough or your screws may be stripped enough as to not tighten down properly. does your clipper sound like the motor wants to slow down when you try using them for an extended time? if so replace the clippers. did you take apart the clipper housing and make sure it is free from all hair? sometimes hair will get into the motor area and cause the blades not to work properly.
  • 12 Answers
SOURCE: Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Posted on Aug 11, 2009
  • 30 Answers
SOURCE: Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Posted on Sep 21, 2009
How do you adjust the head to cut various thickness of your dogs hair?
RTM. Read the manual. You're probably not using the correct blade and size.
Aug 06, 2014 | Wahl Animal Clipper Pcmc-2 Dog Cat Horse...
Cut
Try oiling clipers and shave slow and easy
Jul 30, 2013 | Wahl KM2 Hair Trimmer
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
Clippers dont work at all, don;t cut hair and the dog hair is trapped
A reason your trimmer may not work is that the hair is trapped inside the trimmer and not allowing it to function properly.
Here is a link to a video to cleaning hair clippers.
www.youtube.com/watch?v=43CpUK2AghA
If the problem persists, then you most likely burnt up the engine in the clippers and there is no easy solution other than buying a new trimmer.
May 02, 2011 | Wahl 8550
My newly bought WAHL hair clipper but it is not sharp enough to cut my hair. what can i do to solve this problem.
The only thing here you can do is, if you want your blades to be sharper you need to send them to a professional sharpening service. Manny's Sharpening can help you with that, We have a mail order service with includes Free return shipping. We only charge $8.00 per blade set.Check out my web page, we also included a shipping Label and order form. Manny's Mail Order Sharpening
Mar 13, 2011 | Wahl Magic Clip Clippers Hair Trimmer
U can hear the motor running but the blades not moving or cutting
You need to have your blade sharpened or replaced . It is very inportant to clean and OIL !!
after each use!. oil oil oil
You can go to a dog gromer or a hair salon and ask then who sharpens there shears.
Oct 09, 2010 | Wahl 9765-301
The moving cutting edge keeps going diagonal to the bottom cutting guide- to the point where it overlaps and chews into skin! how do i fix this?
if this is a Wahl clipper Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 15, 2010 | Wahl Super Taper Hair Clipper 2000 Hair...
I lost my job, and am in need of dog haircut instructions.
I had a dog with hair. I couldn't afford to take her to the groomers, so I bought an Oster Animal Hair clippers and just buzzed off the hair myself. They have little attachments to go on so they don't cut so short. If you mess up, the hair grows out. My kids used to laugh at some of the hair cuts. I had to train Buttons to hold her head very still when I cut around her eyes. That part scared me, but she did hold still. Some times I had to let her run around awhile and come back to the hair cut in 10 minutes. I also had to train her to lay on her back for the tummy & chest trim. She never did like the toenail trim though. I had to sit on her to get it done. Luckily she was only 13 lbs. I did her hair twice a year and sometimes 3 times. I used the scissors on her feet too. Check at Fleet Farm, Target, or Sally's Beauty Supply for cutting tools.
Mar 29, 2009 | Google Computers & Internet
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Oct 04, 2007 | Health & Beauty
Wahl Super Taper Hair Clipper 2000 Hair Trimmer Logo
99 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
