Question about Grilling
Propaneblowup installed new propane bottle went to start bbq gush of fire with alot of gas.. everything was tight. maybe regulater 6 months old
    Scholar:
    New Friend:
  • 80 Answers
Regulators rarely go bad unless very old but it is difficult to provide a solution with not enough details. contact me for assistance or leave more details. are you using a large LP cylinder? where there flames or only a lot of gas? what kind of grill is this, what kind of burner?
Posted on Nov 08, 2013
SOURCE: no gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Posted on Dec 22, 2008
garing
  • 998 Answers
SOURCE: Very little gas getting to burners
when you first turn tank on let it sit3-4 minutes to let the regulator adjust it's self befor you open a valve
Posted on Aug 24, 2009
  • 3253 Answers
SOURCE: Despite changing everything from the
is there a flame safety device on the burner /is it out of postion
Posted on May 25, 2010
  • 532 Answers
SOURCE: grill does not get hot. I have a fresh bottle of
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Posted on Jun 15, 2010
cadesertmax
  • 274 Answers
SOURCE: model 720-0164 bbq low propane to
What you have is a classic symptom of a bad regulator. If no gas is going fromt he new tank to the burners, you can bet it is the regulator. No real way to test it once it stops working all together. As it is going bad, the flames on the burners will get smaller as each buner lights.
Posted on Mar 20, 2011
Testimonial: "thank you that is exactly the problem! "
I have used this bbq once and it did not heat up enough to cook sausages ,what are we doing wrong and how can we fix it ,we used just a normal lpg gas bottle as we can not find propraine
I question if the gas in the ipg bottle is propane. All gases have different latent heat. Use the gas and bottle size that the manufacture recommends.
Aug 14, 2010 | Thermos Grill2Go Fire+Ice
Low gas output on BBQ Galore Grand Turbo
check the gas line is not blocked and check the reg presure see if burners or orfice are blocked if so clean them check gas bottle is full
Apr 18, 2010 | Barbeques Galore Grand Turbo 175776...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
Very little gas getting to burners Full bottle of propane Acts the same way as when the propane bottle is getting empty This grill is only about 6 months old
You either have clogged burners and they need to be cleaned. Clogged inlet line to the burners. (This can come from trash, spiderwebs etc in the connection, kinked line etc.) or the regulator is malfunctioning.
Aug 24, 2009 | Weber Genesis E-310 Gas Grill
Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
No gas getting to bbq
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
