Question about Honeywell Programmable Thermostat Heater
I converted to natural gas and plumber replaced my four thermostats with rth2300. Programming seems straight forward, but the heat won't come on. Plumber tells me it's the programming I am not doing correctly. What am I missing? I am following the programming step by step
    Master:
  • 571 Answers
Call an HVAC technician to check the wiring...they will be more helpful for thermostats.
Posted on Dec 12, 2013
I have baseboard heating and not sure if i bought the right thermostat there is a switch inside fir gas/oil or water pump/elect. modle # rth2300/rth221
No. Baseboard heaters will use a 120v or 240 thermostat. The thermostat you have is for 24v low voltage only. Hope this helps!
Dec 08, 2013 | Heating & Cooling
Need to know if it will work
Think you need a different thermostat...you will need one for line voltage, not low voltage.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
Rangemaster 110 on lpg wish to convert to natural gas
You must get a tradesman or technician who is qualified to convert a gas appliance, your local gas fitter or plumber should be able to help with this. the regulator needs to be changed the jets also need to be swapped out for the type of gas to be used. normally from lpg to Natural gas the jet size needs to be increased by installing new jets or by drilling out the old ones
Hope that helped
Oct 22, 2013 | Rangemaster 110 (Gas) Kitchen Range
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
May 14, 2011 | Weber Genesis Silver B Grill
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Rinnai 560PTR Heater Converted Propane To Natural Gas No Ingition
I think you will find the thermocouple or thermostat has gone this allows the gas valve to open and is a saftey device to stop the escape of dangerous fumes .. it looks like a long piece of thin copper wire approx 4mm thick and it extends from the main valve into the pilot light flame .. When the ignition is pushed and you hold your finger on it for a while this tells the the valve that the pilot light is lit .. conduction of heat along this pipe then opperates the diaphram in the valve allowing the gas to the burners the pilot light then ignites them .. if the pilot light goes out the unit will nort run ..
My advice to you is that even though you may be conversant with the heater .. they do tend to have all manner of faults occur when left in storage or if shipped ( jostling and bumping ) is to get a trained gas engineer to check it out it may cost a bit .. but a gas escape and the following reprocussions are far more exspensive and costly .. Also You may not be aware that if you do have an incident your house ,insurance may be null and void if no service documents can be raised for the correct servicing of a fixed or mobile gas Convector .. I hope this helps Regards Vortash
May 22, 2009 | Heating & Cooling
Dacor pgm 365 lp to naural gas
Yes by a licensed person so as not to break any local laws or Kill You,
LPg typically delivers at a higher psi than natural gas, and the propane content requires more combustion air than the methane butane mix of natural gas,
methane CH4 needs 2 oxygen (O2) to make CO2 +2 H20
Propane C4H10 needs 7.5 (02) 4 CO2 5 H2O
the nozzle injecting the LPg has small diameter, The Gas certified plumber can remove the nozzle(s) and replace them with larger diameter Natural gas ones for a small price, most manufacturers make both, its a simple job
Cant stress - Gas Certified plumber/tradesman - strongly enough, one explosion will ruin your whole day
May 09, 2008 | Dacor Preference SGM365SS Gas Cooktop
Heating & Cooling Logo
100 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
