Question about Refrigerators
Kenmore bottom freezer evaporator fan - Refrigerators
  • 5 Answers
SOURCE: ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Posted on Apr 02, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
rylee_smith
  • 8619 Answers
SOURCE: Have a customer with a
Hi
Please see these exploded diagrams for GE Bottom Freezer---
Also see these pictures---
Click on the pictures to see magnified views.
Also see this picture--
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 21, 2009
mrfixit3667
  • 262 Answers
SOURCE: My Kenmore refrigerator freezer defrost water
Your Defrost drain is cloged. you will need to remove the back wall to get to the drain and then defrost it with hot water. have lots of towls ready. and make sure the hot water is poured in the pan under the evpaerator. you might also look at the back of the machine to see if there is a drain tube, some of those top mount have a tube on the back.
once the water starts flowing your good.
Posted on Jan 08, 2010
  • 906 Answers
SOURCE: Kenmore 596.72913200 refrigerator cold, freezer cold but not freezing
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
I have a Kenmore Elite side by side refrigerator, the problem is the unit is not cooling at the top area of both the freezer and refrierator? the bottom areas are OK, I notice there is no air flow in the...
Is your fan inside the freezer compartment back wall towards the bottom is working. (Evaporator fan motor) ?
No fan... No circulation.
Fan may have failed or another common thing is failed defrost system has clogged up the evaporator coil and fan blade with frost. In this latter case, you will see white frost build up in the freezer back wall towards the bottom in freezer compartment.
Better call a local service technician. Little bit technical and hands on job.
Oct 23, 2017 | Kenmore Refrigerators
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
Kenmore bottom freezer ,back of the
replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 28, 2009 | Refrigerators
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Dec 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Cold on bottom, Hot on Top - 596.75303
You are right on the money. I would definitely buy the fan kit because the problem will get worse. I had to replace the evaporator fan on my parents fridge and it was only two years old. You can also download the breakdown diagrams and schematics from http://www3.sears.com
Jul 08, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
FAN MOTOR NOT OPERATIG
1. remove everything from freezer. 2. unplug freezer. 3. remove screws from back of freezer wall. 4.remove evaporator fan. (you will see it at the top of the freezer wall) 5.install new one.
Mar 12, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
