Question about Lasko 2515 Tower Fan
Main fan doesn't work - Lasko 2515 Tower Fan
I have a minka aire fan and my remote doesn't seem to work. (UC7084T)
1. Shut off main power to the fan (circuit breaker)
2. Remove batteries from the remote and press all buttons to eliminate possibility of a stuck one. Reinstall batteries
3. Turn on main power and try remote
Jan 26, 2013 | Minka Aire Ceiling Fan
My refrigerator dose not cool freezer or main section, motor and fan work
check for the thermostat knob which malfunction doesn't turn on.
Aug 10, 2012 | Refrigerators
2003 ford focus, overheats when AC is on
Have the radiator checked for blockage and replace the thermostat. If the above doesn't cure the problem you may have a leaking cylinder head gasket
Jun 11, 2012 | 2003 Ford Focus
My powered sub woofer system doesn't work.power indicator works and fan doesnt no sound
You will need to contact JVC online, customer support and the technical department to see if they can provide at least download on the circuit diagram. The powered sub from your description has a short, probably the main ic that is heatsinked.
Nov 26, 2011 | JVC Audio Players & Recorders
My fan doesn't work nor does the motor make a sound.
Need help with a fun like to bypass the which
Sep 24, 2011 | WeatherWorks CH-1640SF Fan
I have a Hampton Bay Windward II ceiling fan. Fan works fine but fluorescent light doesn't. Have done some troubleshooting. Obviously 120V input is OK otherwise fan wouldn't work. Wires to the...
sounds like there is a lose or broken conection from were the feed to the balast slits from the main fan conection try rewireing from the live imput to the balast see if that solves it.
Jul 30, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
AIR DOES NOT SEEM TO BE COOL ENOUGH LAST YEAR HAD SERVICE COME AND PUT FREEON IN
hi,
If the the AC doesn't get the cooling then the main reason will lack of freon gas.
Is the fan works perfectly. Also check the fan is it working perfectly. If the fan is ok then you have to refill the freon gas again.
ok
Jun 09, 2011 | Frigidaire FAL125K1 Air Conditioner
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Heater fan doesn,t work
if you are getting power at the fan plug, it is possible that the recycled motor is bad.
Feb 04, 2009 | 1994 Cadillac DeVille
I put an envelope in the printer since then its doesn?t work, I tried to restart, change the drum and push in a paper by the special slot and it still doesn?t work. Just the motor is turning and the excess...
reinstall printer
then go into properties, click main, where it says TYPE click plain paper, where it says SIZE click on the envelope size you want to use, then click ok
Feb 02, 2009 | Brother HL-2040 Laser Printer
Lasko 2515 Tower Fan Logo
32 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Shehu Pro
Shehu Pro
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
