Amstron HP Pavilion tx2000 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter Logo
C
Chanel Gray Posted on Oct 23, 2013
My webcam and microphone wont work - Amstron HP Pavilion tx2000 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter
madd_jgi
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 46 Answers
  • Posted on Oct 29, 2013
madd_jgi
Contributor
Level 1:
New Friend:
Cheetah:
Answers
46
Questions
Helped
3982
Points
85
You need a technician to open the screen and the laptop to check the cables if they are connected properly.
What you can do though is go to control panel> devices and printer and check if they are shown, if so, go to the hp site and try to get the drivers or google them.
Best Regards
1helpful
Does an acer aspire one have a built in microphone
If it has a built in webcam, then it has a built in microphone (usually a hole next to webcam). Otherwise, use a cheap headset.
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
8helpful
2answers
Microphone not working
How to get your webcam microphone to work: Click on Control Panel, Hardwre and Sound, Sound, Recording. You should see your microphone icon with a Green check mark on it. If there is no Green check mark, it means it is disabled. If there is No green mark on Microphone it never works. To enable the Microphone Right click on Microphone and click on Enable. If you do not see the Microphone in the list, Right click on the White space and select Show disabled devices. Then you would see the Microphone. However, if you do not see the green check mark on it, Right click on it and click on Enable. And also Select Microphone and click on Set Default (If Set as default button is active).
If you see the Green check mark on Microphone the Microphone definitely works.
Step 3: Increasing Microphone Sensitivity and Un-muting the Microphone.
1. Select Microphone and click on Properties button.
2. Adjust the slider until to 100 % of its range.
3. If Mute is on, click the mute button to un-mute the device.
4. If Microphone Boost is available, boost the volume.
5. Click OK to make the changes.
Now the Microphone should work. To verify you can test it on the free webcam test tool site.
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Microphone wont work
You do not say what OS you have but you need to check that the webcam mic is set as default.
Vista
TEST SPEAKERS
Restart computer
Configure to your chat program
If you have an earlier OS you may have to access your hardware from your Control Panel
2helpful
Icannot get webcam microphone to work.how do i hook up microphone
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
8helpful
Dont Know How To Turn On Microphone on webcam
2helpful
Microphone on my webcam
2answers
Top Amstron Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Amstron Computer and Internet Expert? Answer questions, earn points and help others
