Question about Ovens
How to replace the seal on Electrolux oven between oven and door
    Problem Solver:
  • 7 Answers
This might not be helpful to you, but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal on my Miele.
Posted on Nov 21, 2013
4 Suggested Answers
SOURCE: The glass has shattered in my electrolux eou6330x door
It will be difficult to find just the glass, have it shipped and fumble with getting it into those factory sealed doors. The entire door can be purchased for right about $50. Click here to see. There is not a picture associated with this item, but it is the correct part number.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Feb 22, 2010
Testimonial: "thanks"
SOURCE: Resealing Inner Oven Glass
I guess you worked this out already as posted a while ago....but for others like me I thought adding a solution might help..........Open the door fully and on the hinges there is a clasp, flick that back on itself on both hinges. Close the door carefully and it will stop half way....now lift the door off the hinges. Lay the front of the door on the floor and there are 4 screws on the bottom of the door...unscrew the middle 2 (the outter 2 attach the hinges). then lift off the back of the door....you now have the access you need!
Now i have done this I need to get the sealant....is there a shop you can get this from B
Posted on Oct 09, 2010
caroldon
  • 17129 Answers
SOURCE: I require fitting instructions diagram for
There is a lot of help for spares and service in the link.
Please check the links below:
http://www.espares.co.uk/advice/cooker-hoods/a/6
http://www.espares.co.uk/search/cookers-and-hobs/p/1092
Posted on Jul 12, 2011
How do I fit a seal to an Electrolux oven with rounded corners and no clips
Good Afternoon friend, thank you for your post!
I understand that you need help with the seal on your Electrolux oven. Could you provide me with your model number, please? The serial tag is located on inside wall of your oven. With that information I can provide you further assistance. -Matt
Feb 12, 2015 | Electrolux Ovens
Where do you get the double sided tape to stick the glass door back on oven door?
Far as I know the glass oven door is sealed with special silicone putty that is resistant to a temperature of 300 Celsius .
Previously, the required perfect clean the surface with alcohol.
Dado
May 23, 2014 | Electrolux EOG9330 Gas Double Oven
Can I get a replacement for the lower oven door of an Electrolux EDC6935 wall oven?
Hi Mike - I am happy to assist you. First, according to my research, the model number that you have provided me is appearing invalid according to the Electrolux database within the US. Are you located outside of the US? Generally speaking, for some units the complete door set would need to be replaced. However, may I please have the correct model number, to better address the issue at hand? Typically the serial tag is located in the storage drawer on the right side. Thank you and I look forward to your response.
Jun 18, 2013 | Electrolux Ovens
Our ELECTROLUX EOEE63AS oven door will not shut properly have got nowhere with ELECTROLUX SERVICE HERE IN South Australia, any clues!! Mal
Don't waste time with a new door like I did. The door hinge is poor design in my opinion. Buy 2 super magnets on eBay, there's a seller a Flinders Park in S.A. The magnets should be 24mm x 9mm x 3mm thick. Place them top left and right of the open door outside the seal on the stainless panel. See pic.
Problem solved.
Feb 15, 2013 | Ovens
There appears to be a film on the inside oven door glass. It just appeared. How can I get rid of this?
if this is between the glass you are going to have to remove the glass and clean it... the most common reason for this is poor sealing the door liner or insulation in the door is failing ... if you also selk clean the oven often the excessive heat will cause this.. its a fairly easy process to fix just requires a little patience and time... good luck
Jan 02, 2011 | Electrolux ICON Designer E30SO75ESS Oven
i live in az here i use aplace called appalince depot . check phone book or net for something similar
Feb 22, 2010 | Electrolux EOU6330 Electric Double Oven
Main oven door not sealing. How do you adjust the cam type action of the hinges to ensure flush seating of the door? thanks
If it has a drop down door, then no adjustment is possible, the only solution is to replace both hinges.
Please rate my solution.
Thanks.
Nov 11, 2009 | Electrolux Ovens
Jul 16, 2009 | Electrolux Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
