Question about GE Dryers
I have a GE gas dryer DBVH512GF1WW. The heat is inconsistent. I noticed the ignitor glowing and then a flame shortly after on the initial time I turned the dryer on. Then after the flame going out after a minute or so, a minute passes and the glowing ignitor comes back on but no flame. Repeated glow and no flame. Is there a definite piece I need to replace? I checked for continuity on all that I could and everything seemed to read ok. PLease help, thanks!
  • GE Master
  • 2,330 Answers
Sounds like bad gas coils located on top of the gas valve,when the coils start to fail the ignitor will glow,the coils let the gas in until the coils heat up and then ignitor glows but no gas.when the coils cool down they might work again for a short time until they heat up and fail again.if the flame lights and goes out after like 30 seconds and goes out and keeps doing this you have a block either in the dryer or the vent line but it sounds like you have bad gas coils.unplug the dryer,get at the valve,pull off the wires going to the coils and check them with a meter,one should be open,just remove the two phillips screws pull off the cover and slide the coils up off of the posts,unplug them and put the new coils on,you'll see like a little piece of plastic on the top of the coils,this fits intoo the cover so they line up correctly and holds them in place,also on the larger coil there's a spacer on the post,if you don't see it look inside the old coil,poke out the spacer and slide it onto the post and then install the coil.
Posted on Oct 23, 2013
catriver
  • 878 Answers
SOURCE: Dryer not heating
odess, sounds like you need a new set of coils for the valve. Easy job. Remove the bottom access panel and you will see the gas valve. Remove the top screws from the coils and the coils will lift off and then unplug the harnesses. Install the new coils. Part number for your coils is 12001349. Price about 18.00 Check them out at repairclinic.com This should take care of your heating issues. Catriver.
Posted on Oct 01, 2007
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
  • 14 Answers
SOURCE: dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Posted on Jul 25, 2008
lsteward68
  • 331 Answers
SOURCE: Kenmore 110.74832400 dryer runs but no heat is
the solenoid is going bad on you. there should be two on the bottom by the front of the machine... gotothis site www.techray1.com and click on the guru guy on the left. this will take you to the site where it will sell it to you cheap and installation instructions
Posted on Jun 15, 2009
SOURCE: glow ignitor works, but no flame ignites. ohmed out gas valve coil with wires disconnected = OL is it my coil?
You have a bad flame sensor. Replace it.
Posted on Sep 18, 2009
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Dryer not heating
Oct 01, 2007 | Dryers
No heat coming from dryer
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 30, 2009 | Whirlpool Dryers
I have maytag dryer and it is blowing cold air. Everything else is working.
If there is no heat then the thermostat or heating element (for an electric dryer) is not working.
If a gas dryer with no heat: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Nov 24, 2009 | Office Equipment & Supplies
The dryer does not heat
Nov 19, 2009 | Whirlpool Dryers
My whirlpool dryer wont heat up
Oct 27, 2009 | Dryers
Gas dryer tumbles but is not heating up
Aug 25, 2009 | Dryers
Dryer Model DE306 has stopped heating
Aug 13, 2009 | Dryers
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
Dryer runs-no heat
I had a problem once with a gas dryer that would come on, the pilot would glow and the flame would run on a shortend cycle. The coil that opens the gas valve had a short circuit that would only short out when it heated up. It would drive me crazy since it appeared to be working. The short cycle time the first time, and then maybe not at all once it was warm gave me mixed signals.
May 15, 2008 | Dryers
Dryers Logo
132 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
