Question about Home
Vortens toilet double flush How do you replace the
Vortens toilet double flush How do you replace the seal on the flush valve? How do you disassemble it , to get to it?
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
co7196
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
ExHandyman
  • 86 Answers
SOURCE: My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Posted on Apr 09, 2010
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
Posted on Jul 19, 2010
How do I stop water running into pan after toilet has been flushed &refilled.
If there is water still running into the toilet bowl, there is a problem with your flapper or flush valve. The most common problem, and least expensive to fix, is the flapper has gone bad and is allowing water to escape past it. Replace the flapper and the water should stop running. If not, it is possible the flush valve or one of the seals holding it to the tank has gone bad and needs replaced. Try replacing the whole flush valve. They come in a kit that includes the valve, flapper, and seals.
Feb 26, 2015 | Home
SL tank carrier unit just installed last week.work fine the first few times, now water keeps running into the toilet bowl
hey, since it is new, I assume a small stone or left-over is stuck where the seal is, You need to disassemble the valve, clean it and re assemble. Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi Grohe GD2 flush system concealed cistern repair fix and disassembly...
Apr 26, 2014 | Grohe 38749001 Rapid SL In Wall Carrier...
Water leaks from tank to bowl all the time
It is most likely the flush valve gasket. This is the equivalent of a flapper on a normal toilet. You can purchase these seals at plumbingmall.com 750017 Outlet Valve Seal for M5 Flush Valve
Aug 06, 2013 | Caroma Sydney Smart 270 Elongated Dual...
Flush tank leakage
hey,
If it is new, I assume a small stone or left-over is stuck where the seal is, You need to disassemble the valve, clean it and re assemble.
If it is an old installation, it is possible that the seal is worn and need to be replaced.
Have fun
Avi
May 24, 2013 | Grohe 38 749 001 Rapid SL Flushing System...
My toilet keeps running. I tried to adjust the float with a phillips but that did not work. There is slight leaking into the chamber over the top.
If there is a continual leak in to the toilet bowl you will likely need to replace the flush valve or the toilet flapper.
As a first step try try cleaning the sealing surface of the flush valve to se if the flapper will seat and make a seal.
If this does not work and the flapper is visibly detioriated and breaking down shut off the water supply, remove the toilet flapper and visit your local plumbing supply store to purchase a suitable replacement. Install the new flapper, turn on water supply.
These illustrated instruictions may also assist:
http://www.danco.com/HowTo/How-To-Replace-a-Toilet-Flapper
Although less likely, if the sealing surface of the flush valve is damaged or detioriated proceed with replacement of the flush valve. Again turn off water supply and follow the instructions set out here:
http://www.danco.com/HowTo/How-To-Replace-a-Flush-Valve
If there is not a leak in to the toilet bowl and the water flow does not shut off completely, then water is flowing through the fill valve and the overflow pipe and you may need to adjust the float and float rod to allow clsoure of the fill valve. See here:
http://www.danco.com/HowTo/How-To-Replace-a-Float-and-Float-Rod
Mar 09, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
I bought a brand new home about a year ago and it came Vortens toilets. I've noticed the tank handles break easily. They are made of solid plastic and they don't last long at all. If I had my choice I...
As long as your toilet has about a 3/4 inch hole in it then practically any flush handle you like will work. Lust remember thet the threads on the retaining nut are left hand threads so they look backwards. Also don't overtighten. I can't think of any name brand that I specific like right now so I'd find one you like and go with it.Thank you and have a good holiday
Dec 24, 2010 | Home
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Dec 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Home Logo
52 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
