Question about Maytag MVWC6ESWW Washer
MAYTAG MVWC5ESXWO is not filling completely, agitating at start of cycle prior to filling, on lasts pin cycle it starts filling with water.
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
landsend
  • 1066 Answers
SOURCE: WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Posted on Mar 11, 2009
dwrooker
  • 6 Answers
SOURCE: maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Posted on Oct 06, 2009
wpcustomer
  • 336 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    richroth
    • 9472 Answers
    SOURCE: I have a Commercial Series
    Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
    Posted on Dec 26, 2010
    My washer does nothing when you put it in the rinse cycle however it does fill with water. I believe the problem is the timer switch. can you confirm this issue
    Not so? If it does not go into agitation? You may have a bad water pressure switch which sends signal to start agitation. but also can have bad cam dogs in agitator which do not engage agitator? a bad door switch will not allow agitation or spin on some appliances. And lastly yes u may have a bad timer wheres points have fused? can check most of these with a multi meter
    Feb 05, 2015 | Maytag Washing Machines
    Washing machine starts agitating before fill
    Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
    Jan 12, 2014 | Maytag Washing Machines
    My washer is starting the cycle on agitation not filling completely and on last spin cycle it starts to fill with water.
    I found what seems to be an easy fix thatt solved the problem with my Maytag Centential washer that stated agitating before it filled with water. After opening the control panel and tilting it back, just pull the clear plastic hose that attaches to the cycle and leveling switch. Blow into the hose and you will probably feel water that's caught in the hose blow out the other end. Reattach the hose to the cycle and leveling switch. Now test it by starting a cycle and hopefully it works for you like it did for me. If you know how to open the control panel, this fix takes about 2 to 3 minutes start to finish. I feel bad for those people that have mentioned having repairmen replace parts that may know actually be at fault. I doesn't appear to be a bad switch, but instead a poor design the sometimes doesn't clear water from the hose causing the leveling sensor to think water is in the tub. This has now happened twice in the three years I had this washer. I hope this fix works for you if you too have premature agitation for the MVWC6ESWW1 washer.
    Oct 23, 2013 | Washing Machines
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
    Hi, Do you know if the washer spins at all?
    It sounds like the coupler has gone bad.
    Please let me know if it spins at all.
    I can send yyou instructions on changing the coupler.
    Vic
    May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
    water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
    Apr 26, 2009 | Washing Machines
    Maytag washer wont start after it fills
    Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
    Mar 14, 2009 | Maytag Washing Machines
    Maytag washer
    This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
    A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
    Check it out and replace it if necessary.
    Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
    Grinding niose from agitator.
    If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
    Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
    Open Questions:
    Maytag MVWC6ESWW Washer Logo
    60 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
