Question about Juki MO-644D Mechanical Sewing Machine
I am trying to thread a kenmore serger 3/4 - Juki MO-644D Mechanical Sewing Machine
    Champion:
  • 208 Answers
You have to be shown physically
Posted on Oct 27, 2013
Threading diagram for rimoldi 3 thread serger model 627
Rimoldi Serger Manual PDF And Ebook Files - DocsFiles
docsfiles.com/pdf_rimoldi_serger_manual.html
Rimoldi Serger Manual PDF Files, Manual For Rimoldi Serger honda nx 250 service ... Manual FREE Parts Crochet - Loopers RIMOLDI 8 8 Kl 327 , 527 , 627 , F27 ...Rimoldi Serger Manual Rimoldi B.27.77 Industrial Serger, 3-Thread, Nov 26, ...
rimoldi 329 threading diagram Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your rimoldi 329 threading diagram question. ... Rimoldi orion 627... rimoldi overlocker how to thread Which Model Rimoldi? ... Level 3 Expert.
rimoldi pdf - P(1) - Docs-Engine.com
Feb 05, 2016 | Sewing Machines
Kenmore 385 #3 thread breaks
Try removing thread #3 from the tension altogether. If this doesn't work, then try using a different spool of thread. Some break easier than others. If this doesn't work, try rethreading your serger from the the beginning. Upper looper first, then lower looper, then needle. Test on scraps.
Dec 06, 2013 | White Sewing Speedylock 1600 Mechanical...
Kenmore serger thread keeps breaking
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Mar 26, 2013 | Sewing Machines
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
#1 thread keeps coming out on the 3/4 thread kenmore serger. How do I fix this problem?
try rethreading the needle & keeping thread tails of at least 4 to 6 inches that you can keep pulled behind the needles
May 03, 2012 | Kenmore Sewing Machines
I just changed my Kenmore serger's needle and it stopped making the overlock stitch. I rethreaded the machine twice and make sure the position of the needles is correct but it didn't help
Hi
If you have the operators manual for this serger, you should be able to follow the threading from the start successfully. Some machines have a better threading diagram on the machine itself.
The needles should have the groove facing the operator's position. They should also be fully inserted in their mounts. Most sergers do not release the thread tensions when the presser foot is raised, therefore, you must zero the tensions to make sure the threads are fully entered into the tensioners when threading anew. After threading, you must readjust your thread tensions to the desired tensions for the set-up you plan to use. Thread tensions should be recorded for each stitch set-up because each serger tends to be a bit different, and therefore, allows you to quickly adjust for the desired stitch needed. The different stitches are adjust and fine tuned by each individual thread tension.
Hope this helps
Ray
Dec 22, 2010 | Kenmore Sewing Machines
Kenmore serger 3/4D, bottom looper thread keeps breaking, can't see where to put the thread before the last lower looper thread hole
Try looking for a free download on wiki, manage my life, or just plain google with your model number, someone will have your answer. As a last resort try tias.com or retrevo, or just plain Kenmore.com customer support.
Aug 14, 2010 | Sewing Machines
Problems With the Tension serger kenmore
Open the tensions (set at zero) and have the presser foot up when threading.
Make sure the antenna if fully extended.
Turn the handwheel so the upper looper is at it's highest position.
Thread, beginning at the right thread cone unless the manual indicates differently.
After threading, set the tensions back to the recommended setting.
If this does not help, please provide more details.
Mar 10, 2010 | Singer Tiny Serger TS380
Juki MO-644D Mechanical Sewing Machine Logo
42 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
