Question about Dewalt 3.7-HP 60-Gallon Single-Stage Air Compressor - DXCMLA3706056
How to hook up the wires on the compresser - Dewalt 3.7-HP 60-Gallon Single-Stage Air Compressor - DXCMLA3706056
04 navigator is blowing ac fuse 11, ac coil shorted, 3 different coils, can ac compress short the coils
How did you hook up the inline fuse to compressor and ground to compress ? Ground what ? Right at the clutch coil ? You have to be hooking it up wrong . The compressor can't cause the clutch coil to short or blow the fuse , even if the compressor were seized up . An before that would have the serpentine belt would burn up , squealing noise. applying B+ voltage in the relay socket ,pin 30 to pin 87 will engage the compressor clutch . If the fuse blows the wiring from the relay to the compressor clutch is shorted to ground . Look for rubbed through wiring harness .
Jul 14, 2017 | Ford Cars & Trucks
My troy bilt tb130 lawn mower won't start even after I changed the spark plug what could be wrong with it ?
Here is the general rule of thumb...if it has spark, compression and gas it should run. So, I would roughly check compression..does it pull normally with some resistance? If it does it probably has enough compression. Does it have spark? take the plug out but leave hooked up to wire and pull to see if there is a spark inbetween the little "hook" and the center of the plug. MAKE SURE YOU HOLD THE SAFTEY BALE IN ON THE MOWER HANDLE (SAFTEY SWITCH). It will pull like it has no compression because the plug is out. Does it have gas? take off air filter and see if you can see any wetness (gas). If it is completely dry it probably isn't getting any gas. Either the screen is plugged in the tank or the carb is varnished up from sitting too long. If you smell the gas and it smells different that means the gas is probably old and the carb will need cleaned out (not always tho). That is another story but not that difficult...
Aug 11, 2014 | Garden
Idyling rough
You need compression, fuel, and spark to make power. So if you are sure that cylinder has spark, it could be compression or a fuel problem.
Mar 09, 2014 | Cars & Trucks
Compressed air horn attatch help for 1997 tomos moped a35
It won't work. Your moped's electrical system won't support that sort of demand.
Oct 11, 2012 | Motorcycles
I have a 1994 ford mustang 3.8 v6, when i bought the car it had a slite misfire,i bought a new coil pack, changed the plugs and wires, I hooked up the coed reader and it pulled up P0302. cylinder number 2...
check your compression, you might have low compression in that cylinder-also check your fuel injector in that cylinder, it may be damaged (wiring/connection) or defective.
Jun 01, 2011 | 1994 Ford Mustang
How do i remove the keys to clean underneath?
What do you want to clean? Use a can of compressed air, vacuum cleaner, or buy a new keyboard. it is not recommended to remove the keys.
Mar 05, 2011 | Computers & Internet
I repalce timeing belt i did evertings put it back it whold not start 2000 honda civic got over heat i change head gaskit and timeing belt.
everything hooked up wires ,ect. check timing and no.1 up compression strke & rotor on distuber is on no.1 wire
Nov 05, 2010 | 2000 Honda Civic
1998 windstar 3 litre number 3 misfire ,changed plugs, wires, coil, injector, any ideas?the only codes are number three misfire
did you leave your battery hooked up while you were replacing the spark plugs and coil and such? try resetting your ECM.
Jan 15, 2010 | 1999 Ford Taurus
I have an 89 Jeep Wagoneer inline 6. Its not
You got the ignition cover, what you need to do an cylinder compression test and also check your injector for voltage while engine running hook test light to battery pos on neg and neg on pos, at injector harness check for pulsation, if you have pulsation elec. system ok, if good compression bad injector.if bad compression piston ring's or valve's.
Dec 08, 2009 | 1989 Jeep Grand Wagoneer
Mower will not start. Replaced spark plug, air filter and fuel filter. Checked oil. Fuse good. Makes the same sound whether the spark plug wire is hooked up or not.
the key word here is the sound, engine must have compression, put your hand over the carb and try to start, if it trys to **** your hand then you should have enough compression, if it doesnt then you probably have a broken valve- hope that helps
Sep 07, 2009 | Garden
Dewalt 3.7-HP 60-Gallon Single-Stage Air Compressor - DXCMLA3706056 Logo
115 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
