Question about Toshiba Televison & Video
Toshiba HD ready TV ct 90158 makes high pitched sound
This TV has worked fine for a while until the last 6 months. 6 months ago, it made a high pitch sound when I turned it on but the audio from the speakers was fine & not distorted. But the picture was distorted in that I could not see the video..but I could barely make out the channel numbers & menu a little. I turned the set off & back on again. It worked & I had clear picture & sound. It happened again almost a month later so I decided to unplug the HDMI cable & the high pitch noise stopped. I plugged the HDMI back in, I was using a HD cable box at the time, and turned TV off/on & it was fixed once again. I decided to save some cash & got a regular digital cable box since then. During the 6 months, the problem would happen more frequently & sometimes required me to turn the TV off/on more than several times to get the high pitched noise to stop & the picture to return. Now I've been trying to get it to work for almost a week now. I've tried leaving the set unplugged for a day, then for two days with the same result. Any help is appreciated
  • Toshiba Master
  • 4,006 Answers
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Posted on Oct 23, 2013
  • Lee Seabron Oct 26, 2013
    Ok thank you so much I will check them out. I've never opened a tv set before so I'll look up some diagrams & safety instructions before I do. I'll let you know how it goes.
  • 1694 Answers
SOURCE: will not turn on just makes squeeking noise three times
Replace IHVT (xformer) Part #259296
Posted on Oct 08, 2007
  • 1030 Answers
SOURCE: high pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Posted on Mar 27, 2008
SOURCE: T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Posted on Dec 14, 2008
  • 49 Answers
SOURCE: HL-R6768W not turning on. High pitch spin sound. Bad color wheel?
The high-pitched whine is definitely the color wheel.  The early color wheels had problems and many had to be replaced.  As part of the turn-on process, the TV checks for light and then checks for color wheel sync.  If the bearings are wearing out/dried out, it could cause issues with getting the proper color wheel sync, causing the set to not pass the turn on sequence.
Check Sears or partstore.com for a color wheel.  I like sears for experimental replacements since they allow easy returns.
BTW, mine is an early 61".  My color wheel was replaced when I had to replace my Light Engine.  My in-laws 50" was an early one and theirs went out within 2 years.
Posted on Jan 24, 2009
SOURCE: Toshiba 44NHM84 won't turn on
Usualy these problems are due to solder evaporating under the heat of the component.If you are a competent technician,by opening the tv set and by looking closely on the solder part of the board,
you should see a few that are not as shiny as the other, or look like a donut around the pin.these should be redone.those failiure are around the components that heat up:voltage reg,h-v reg and the
resistor around them.
good luck
Posted on Jan 28, 2009
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
Vizio high pitch noise while watching
It sounds like the speaker wire it not grounded good. It sounds like a high pitch whistle or crackle.
May 05, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Same problem, high pitched noise over regular sound and no pictur
No guarantees with this diagnosis. But it sounds like an HT ( high tension) leak This is often caused by the lead becoming partly unplugged ( being bumped or moved) and because of dust buildup it arcs making a high pitched hissing whistle.Ther lamp may also have been affected by the HT leak. The safest option for you is to call a service technician to it, as opening it up could cosntitute a a danger to the unskilled.
Aug 12, 2009 | RCA HD56W58 56" TV
Loud, high pitched hum from speakers . . .
This is GroundNoise from the TV's Backlight.
Sorry, but unless you are a Technician, you will simply need to ignore it.
If you are a technician, you can fix this by grounding the Audio ICs to the Power Supply (details not provided)
Jan 30, 2009 | JVC LT-26X506 26 in. LCD Television
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Televison & Video Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
