SOURCE: cigarrette lighter wont work
using a test light touch each side of all the fuses one at a time lift seide then right side of fuses. if power on only one side then bad fuse. this fuse should be the same as the radio or acc fuse. also check power to the back of the socket as this connection sometimes burns out.
Ps dont forget to rate the solution. Thanks
SOURCE: fuse box diagram
http://www.genuineservice.com/genuineservice/en/default?page=genuineService
Go to this website and pick owner guide on left task bar. Input your info and then pick owner guides.Your fuse information will begin on page 118.
SOURCE: Need a fuse box diagram for a c320
hello,fuse number 47 at your engine room,open your hood,right side,standing in front your car, or you can order to your dealer,fuse designation,ty
SOURCE: 2005 mazda tribute cigarrette lighters dont work
all cigarette lighters in vehicles are ran to a 12 amp fuse. look wherever your fuse panel may be (under the hood, in next to the steering wheel) and see if you need a new fuse. good luck
SOURCE: it appears the fuse controlling
The radio and lighter are on the same cig lighter fuse located in the fuse box at the left lower dash, it may be under a plastic cover, the fuse locations are marked on the cover.
