Question about Video Game Consoles & Games
How do i connect tv philips model 50pfl3707/f7 to xbox 360
4 Suggested Answers
  • 63 Answers
SOURCE: XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Posted on Nov 25, 2007
thegoshem
  • 61 Answers
SOURCE: XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
Posted on Jun 16, 2009
SOURCE: CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Posted on Apr 30, 2010
My Philips 50PFL3707/F7 when pushing the power button on, The menu will flash 9 times color is white and then shuts off. No picture and sound of clicking on and off will occur. please help me.
These flashes are fault indications. Normally, to Philips, the counting of the number of these flashes are not direct. It is coded. If you wish to know more about how to count these flashes, and to get the error code from these flashes, check the site linked here. it is not practical to type in all the details here by this window.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 07, 2013 | Televison & Video
Screw
Many screws work but in the field I use lag screws. usually a 7/16th by about 3 inch (depending on sheet rock thickness). You will need to hit the studs with these.
Jun 14, 2013 | Philips 50PFL3707/F7 50-Inch 60 Hz LCD TV...
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Intec G8621 Wireless Remote Control For Xbox 360 - Need Codes
Does any one know the code for the PHILIPS model 40PFL7505D/F7 HD
Mar 08, 2009 | Sony KV-32FS13 TV
No picture
with the x box 360 it defaults to 1080p and this model does not support that resolution. connect xbox with composite cables and go into x box menu and lower resolution to 1080i and source tv back to original connection and should have picture
Aug 02, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips lx3700d
This HTS can't read opticals
Jan 14, 2008 | Philips LX3700D System
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
