Question about Nordic Track NordicTrack Treadmill, A2550
Exp 1000 belt
I'm not sure if it's model A2550 but it says EXP 1000 below the control panel on the base. Anyway, the belt is all the way to one side and I can't move it, whenever I go over 4 speed there's really bad friction and noises.
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
See the video and proceed according. lube the rollers bearing front+back too.
God bless you
Posted on Oct 23, 2013
  • 103 Answers
SOURCE: belt on nordic track exp 1000 not moving
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Posted on Nov 13, 2009
FrogCatcher
SOURCE: NordicTrack Exp 1000...stops after 40-55 minutes
My EXP000 is doing the same thing. But it is doing it when it is cold also.
http://sites.google.com/site/antiquebriggsandstratton/
Posted on Nov 18, 2009
Gackmaster
  • 12 Answers
SOURCE: My Nordic Track Exp 1000 X runs in reverse.
Your treadmill runs on a permanent magnet DC motor. If it is running backwards someone has swapped the pos and neg leads where it connects to the motor control board MC-60. OR
the brushes were removed from the motor, and installed into the WRONG locations. there is a plus sign and a neg sign on the end cap of the motor, make sure the RED wire is going to the pos sign,.and so forth.
to get to the motor you'll need to remove the 4 phillips head screws FROM the bottom of the motor enclosure: lay the unit on it's side to get to them. 2 in the front,.and 1 on each side. If it doesn't come off easy,.you've missed a screw.
Lay the unit back down, and start digging in.
Lastly, you can verify the MC-60 is outputting the wrong polarity voltage with a voltmeter. Disconnec the motor and connect your voltmeter on a 20 volt DC range ( at least). plug your unit in, and turn it on at 3 mph. you should see positive voltage applied to the read lead.
It's very unlikely that the control board would swap the polarity, so, my bet is,...the wires are switched.
good luck.
Posted on Jan 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: nordictrack exp 1000 trips safety and stops abruptly...
Inspect belt and deck. The deck should be smooth without any grooves, pits, or exposed wood. The belt should have a consistent ridged feel from one side of the belt to the other (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. Very worn belts will feel smooth in the areas you normally walk- you would think smooth is good but not in belts because the smoother the belt, the more contact area. Continued use of your treadmill may damage expensive electrical components. 85% of all Treadmill problems are cause by worn belt and deck I would revisit the scene of the crime again.
Posted on Jun 11, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordictrack EXP 1000 belt runs but stops when I get on it. Drive belts are tight
1) Try to loose a little the drive belt, for to avoid a higher tension.
2) LUBE very well the deck belt, must shure is worn, proceed with the instruction manual maintenance.
3) Test the input voltage motor, if there are voltage the motor need repair
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faultyl.
See my personal TIPS for HELP.
Try to RUN THE software calibration for diagnose, and troubleshooting
sincerely. God bless you
Posted on May 06, 2012
How do I adjust the walking belt?
If you can remove the necessary covers to find the adjuster mechanism(s) do so and then adjust one side of the belt until it runs true again. Otherwisw get a manual from the Nordic Trac website and follow those instructions.
Oct 04, 2014 | Nordic Track Nordictrack Exp 1000...
Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
How do i turn on a nordictrack treadmill exp 1000 x
they have a small switch Red in lower part to the side to the power cord.
see you instruction manual, or download free www. iconservice.com
God bless you
Jun 17, 2012 | Nordic Track Nordictrack Exp 1000...
Apr 24, 2012 | Nordic Track Nordictrack Exp 1000...
My exp 1000 sudenly stops , the counters reset to 0 all the lights are on but the control pannel is nonresponsive an error code 07 showed up once. Any ideas?
I don't have any suggestions for fixing it but I wanted to give you a resource should you need to purchase a new motor control board, you can choose your specific model and browse parts list here. Hopefully you can get it to work though, depending on the model it looks like a replacement can run you $100-$200.
Feb 21, 2011 | Nordic Track Nordictrack Exp 1000...
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
Manual
download it from the nordic track website.
Feb 01, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
145 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
