Question about Dryers
Kenmore dryer model 66901691
Want a inside look of the dryer to find out why the dryer won't start
garing
  • 998 Answers
SOURCE: Kenmore dryer model 11063022101 quit working.
check door switch
Posted on Aug 31, 2009
heatman101
  • 43501 Answers
SOURCE: My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 05, 2011
  • 72 Answers
SOURCE: Why does the inside light stay on and the Kenmore
There is a switch in the door jamb that turns on the light and also allows the dryer to start. If you close the door and the light does not go off like it did before, then that switch is probably bad.
Posted on Aug 31, 2011
mechanicsonl
  • 431 Answers
SOURCE: kenmore dryer model 110.66722692 won't start
does the drum travel up and down losely. if so the spindle at the rear of the drum in the centre has worn and needs replacing
Posted on Dec 21, 2011
richroth
  • 9472 Answers
SOURCE: my kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Posted on Oct 16, 2012
Model 64982. Where can I get push to start button?
This is a Sears Model that begins with the number 110.64982 and has more numbers. You should be able to find tag inside dryer door. Once you have the full number any local parts outlet should be able to get the part.
Be awre, this switch does NOT fail often and MAY not be the problem. There are SEVERAL reason why your dryer may not start when button is pressed and you should check those before you buy a part you may not be able to return.
The video below WILL help get you started:
How to Troubleshoot Brown Top Kenmore Dryer that Won Start
Nov 21, 2015 | Kenmore Dryers
Won't work. No service code.
the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
Mar 18, 2013 | Kenmore Dryers
Kenmore dryer model 110.66722692 won't start
Dec 21, 2011 | Kenmore Dryers
Why does the inside light stay on and the Kenmore dryer won't start when the door is closed?
Aug 29, 2011 | Kenmore Dryers
Kenmore model 665.13243 normal wash light is blinking and won't start the new cycle
heatman101
Jul 07, 2011 | Kenmore 65924 Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
